Re: Scootergrisen's VGA Vax
: 29. december 2021 17:13
Billeder af styrbolten der holder styr og forgaffel sammen.
Billeder af styr hvor speedometer, forlygte og forblinklys sidder.
Snak om scooter og knallert og få hjælp til dit køretøj
https://scootergrisen.org/forum/
Temperaturen (omkring -2 til 0 grader celsius) skulle da i hvert fald være inden for batteriets afladningsområde.Discharge environment: -20°C~60°C
Battery working humidity: 80%RH
5. BMS Functional Description
3. Overcharge protection and its recovery
• When the maximum cell voltage is higher than the maximum protection voltage of the charging cell, the BMS enters into the overcharge protection state and cuts off the charging MOS after the delay of 3 to 5 seconds.
• When the maximum cell voltage is less than the removing protection voltage of the charging cell, the BMS exits the overcharge protection state and reopens the charging MOS.
4. Over-discharge protection and its recovery
• When the minimum cell voltage is less than the minimum protection voltage of the discharge cell, the BMS enters into the over-discharge protection state to cut off the discharging MOS after the delay of 3 to 5 seconds.
• When the minimum cell voltage is higher than the removing protection voltage of the charging cell, the BMS exits the over-discharge protection state and reopens the discharging MOS after the delay of 3 to 5 seconds.
