Vga N1 30 Km/t Ecu Hjælp Euro 4
freddyjensen
Tilmeldt: 19. oktober 2023 14:23
Scootere: vga n1 sym jet 2t herro 45km/t tomos quadro a35
Indlæg af freddyjensen »
Er Der nogen der kan hjælpe med opsætning af denne ecu som jeg har læst ud af min VGA N1. :crazy:
Kode: Vælg alt
[HEADER]
ECS_TYPE=CLC_V504
[PARAMETERS]
N=111
PAR1_DES=ID_MapFile
PAR1_VAL=30002
PAR2_DES=Th_Type
PAR2_VAL=1
PAR3_DES=Th_A_DeltaAccRpm
PAR3_VAL=3000
PAR4_DES=Th_A_DeltaDecRpm
PAR4_VAL=-3000
PAR5_DES=Th_B_DeltaAccTps
PAR5_VAL=200
PAR6_DES=Th_B_Dec_Rpm
PAR6_VAL=1100
PAR7_DES=Th_B_DecTps
PAR7_VAL=5
PAR8_DES=Acc_nRpmDecr
PAR8_VAL=2000
PAR9_DES=Dec_nRpmDecr
PAR9_VAL=1000
PAR10_DES=Air_DeltaAcc
PAR10_VAL=0
PAR11_DES=Air_DeltaDec
PAR11_VAL=0
PAR12_DES=Adv_DeltaAcc
PAR12_VAL=0
PAR13_DES=Adv_DeltaDec
PAR13_VAL=0
PAR14_DES=Adv_DegreeMax
PAR14_VAL=280
PAR15_DES=Adv_LimiterRPM1
PAR15_VAL=9000
PAR16_DES=Adv_LimiterF1
PAR16_VAL=4
PAR17_DES=Adv_LimiterRPM2
PAR17_VAL=9100
PAR18_DES=Adv_LimiterF2
PAR18_VAL=3
PAR19_DES=Adv_LimiterRPM3
PAR19_VAL=9200
PAR20_DES=Adv_LimiterF3
PAR20_VAL=0
PAR21_DES=Adv_LimiterTUNE RPM1
PAR21_VAL=9000
PAR22_DES=Adv_Limiter TUNE F1
PAR22_VAL=4
PAR23_DES=Adv_LimiterTUNE RPM2
PAR23_VAL=9100
PAR24_DES=Adv_Limiter TUNE F2
PAR24_VAL=3
PAR25_DES=Adv_LimiterTUNE RPM3
PAR25_VAL=9200
PAR26_DES=Adv_LimiterTUNE F3
PAR26_VAL=0
PAR27_DES=ClcCheckTime_NoTps
PAR27_VAL=300
PAR28_DES=ClcCheckTime_TpsPresent
PAR28_VAL=30
PAR29_DES=Not_Used
PAR29_VAL=5500
PAR30_DES=Not_Used
PAR30_VAL=6000
PAR31_DES=Not_Used
PAR31_VAL=90
PAR32_DES=Not_Used
PAR32_VAL=2
PAR33_DES=Not_Used
PAR33_VAL=10
PAR34_DES=Not_Used
PAR34_VAL=0
PAR35_DES=Clc_LeanO2
PAR35_VAL=25
PAR36_DES=Clc_RichO2
PAR36_VAL=57
PAR37_DES=Clc_TPSEnLo
PAR37_VAL=105
PAR38_DES=Clc_TPSEnHi
PAR38_VAL=110
PAR39_DES=Clc_deltaTPS
PAR39_VAL=900
PAR40_DES=Clc_StepCycle
PAR40_VAL=2
PAR41_DES=Clc_EnTeng
PAR41_VAL=20
PAR42_DES=Clc_EnRevN
PAR42_VAL=1000
PAR43_DES=Clc_ThresHoldRPM
PAR43_VAL=4000
PAR44_DES=Clc_RPMthCLCOFF
PAR44_VAL=9200
PAR45_DES=Acc_ThRpm_Under_AlgOff
PAR45_VAL=1100
PAR46_DES=Crank_NumRpm
PAR46_VAL=700
PAR47_DES=Warning Engine Temperature Low
PAR47_VAL=150
PAR48_DES=Warning Engine Temperature High
PAR48_VAL=155
PAR49_DES=Emission_Detect_Type
PAR49_VAL=0
PAR50_DES=Engine Temperature Fault
PAR50_VAL=40
PAR51_DES=Air_Frequency
PAR51_VAL=10
PAR52_DES=PickUpOffsetDTC
PAR52_VAL=490
PAR53_DES=Air_En
PAR53_VAL=1
PAR54_DES=Speed_Sensor_Filter
PAR54_VAL=1
PAR55_DES=CLC_En
PAR55_VAL=1
PAR56_DES=CLCCheck_En
PAR56_VAL=1
PAR57_DES=TuneUpCLC_En
PAR57_VAL=1
PAR58_DES=NTC2_En(Teng)
PAR58_VAL=1
PAR59_DES=TPS_En
PAR59_VAL=1
PAR60_DES=Acc_AlgOnTime
PAR60_VAL=0
PAR61_DES=EngStop_En
PAR61_VAL=0
PAR62_DES=AirDoublePWM_En
PAR62_VAL=1
PAR63_DES=AirDPWM_HF
PAR63_VAL=1
PAR64_DES=PickUp Polarity
PAR64_VAL=1
PAR65_DES=TengAdvTuneup
PAR65_VAL=1
PAR66_DES=Acc_ThRpm_Over_AlgOff
PAR66_VAL=8500
PAR67_DES=NTC Fault High Threshold
PAR67_VAL=165
PAR68_DES=NTC Fault Low Threshold
PAR68_VAL=-40
PAR69_DES=Speed_Pulse_Per_Km
PAR69_VAL=30750
PAR70_DES=Speed_Max
PAR70_VAL=44
PAR71_DES=Speed_PID_Proportional
PAR71_VAL=20
PAR72_DES=Speed_PID_Integrative
PAR72_VAL=0
PAR73_DES=Speed_PID_Max_Advance
PAR73_VAL=300
PAR74_DES=Speed_RPM_Treshold
PAR74_VAL=4000
PAR75_DES=Speed_SkipSparks_Limiter
PAR75_VAL=3
PAR76_DES=Adv_DegreeMin
PAR76_VAL=-300
PAR77_DES=Speed_Sensor_EN
PAR77_VAL=0
PAR78_DES=Speed_PID_EN
PAR78_VAL=0
PAR79_DES=Speed_SkipSparks_EN
PAR79_VAL=0
PAR80_DES=ASD_Starter_EN
PAR80_VAL=1
PAR81_DES=TCold_AccDec
PAR81_VAL=20
PAR82_DES=THot_AccDec
PAR82_VAL=120
PAR83_DES=Emission_Temp_1
PAR83_VAL=18
PAR84_DES=Emission_Temp_2
PAR84_VAL=32
PAR85_DES=Emission_Value_1
PAR85_VAL=70
PAR86_DES=Emission_Value_2
PAR86_VAL=85
PAR87_DES=Emission_Time_1
PAR87_VAL=3
PAR88_DES=Emission_Time_2
PAR88_VAL=25
PAR89_DES=Emission_Time_3
PAR89_VAL=50
PAR90_DES=Emission_Time_4
PAR90_VAL=70
PAR91_DES=Emission_Total_Time
PAR91_VAL=950
PAR92_DES=ASD_Full_Power_Emission
PAR92_VAL=1
PAR93_DES=Clc_TPSEnLo_Diag
PAR93_VAL=50
PAR94_DES=ASCII_String_1
PAR94_VAL=51
PAR95_DES=ASCII_String_2
PAR95_VAL=66
PAR96_DES=ASCII_String_3
PAR96_VAL=51
PAR97_DES=ASCII_String_4
PAR97_VAL=32
PAR98_DES=ASCII_String_5
PAR98_VAL=86
PAR99_DES=ASCII_String_6
PAR99_VAL=53
PAR100_DES=ASCII_String_7
PAR100_VAL=48
PAR101_DES=ASCII_String_8
PAR101_VAL=52
PAR102_DES=ASCII_String_9
PAR102_VAL=32
PAR103_DES=ASCII_String_10
PAR103_VAL=51
PAR104_DES=ASCII_String_11
PAR104_VAL=48
PAR105_DES=ASCII_String_12
PAR105_VAL=48
PAR106_DES=ASCII_String_13
PAR106_VAL=48
PAR107_DES=ASCII_String_14
PAR107_VAL=50
PAR108_DES=ASCII_String_15
PAR108_VAL=69
PAR109_DES=ASCII_String_16
PAR109_VAL=52
PAR110_DES=TPS Min Bit 0%
PAR110_VAL=38
PAR111_DES=TPS Max Bit 100%
PAR111_VAL=208
[MAPS]
NUM=19
[MAP1]
N=16
P1A=60
P1B=100
P2A=70
P2B=85
P3A=80
P3B=70
P4A=90
P4B=65
P5A=100
P5B=62
P6A=105
P6B=60
P7A=110
P7B=55
P8A=115
P8B=50
P9A=120
P9B=46
P10A=125
P10B=42
P11A=130
P11B=39
P12A=135
P12B=35
P13A=140
P13B=32
P14A=145
P14B=30
P15A=150
P15B=28
P16A=160
P16B=25
[MAP2]
N=16
P1A=1000
P2A=1600
P3A=1800
P4A=2000
P5A=2500
P6A=3000
P7A=3500
P8A=4000
P9A=5000
P10A=6000
P11A=7000
P12A=7500
P13A=8000
P14A=8200
P15A=8300
P16A=10000
P1B1=130
P1B2=130
P1B3=150
P1B4=150
P1B5=150
P1B6=150
P1B7=150
P1B8=150
P1B9=150
P1B10=150
P1B11=150
P1B12=150
P1B13=150
P1B14=150
P1B15=150
P1B16=150
P2B1=130
P2B2=130
P2B3=150
P2B4=150
P2B5=150
P2B6=150
P2B7=150
P2B8=150
P2B9=150
P2B10=150
P2B11=150
P2B12=150
P2B13=150
P2B14=150
P2B15=150
P2B16=150
P3B1=130
P3B2=130
P3B3=150
P3B4=150
P3B5=150
P3B6=150
P3B7=150
P3B8=150
P3B9=150
P3B10=150
P3B11=150
P3B12=150
P3B13=150
P3B14=150
P3B15=150
P3B16=150
P4B1=130
P4B2=150
P4B3=150
P4B4=150
P4B5=150
P4B6=150
P4B7=150
P4B8=150
P4B9=150
P4B10=150
P4B11=150
P4B12=150
P4B13=150
P4B14=150
P4B15=150
P4B16=150
P5B1=130
P5B2=180
P5B3=180
P5B4=180
P5B5=180
P5B6=180
P5B7=180
P5B8=180
P5B9=180
P5B10=180
P5B11=180
P5B12=180
P5B13=180
P5B14=180
P5B15=180
P5B16=180
P6B1=180
P6B2=220
P6B3=220
P6B4=220
P6B5=220
P6B6=220
P6B7=220
P6B8=220
P6B9=220
P6B10=220
P6B11=220
P6B12=220
P6B13=220
P6B14=220
P6B15=220
P6B16=220
P7B1=250
P7B2=250
P7B3=250
P7B4=250
P7B5=250
P7B6=250
P7B7=250
P7B8=250
P7B9=250
P7B10=250
P7B11=250
P7B12=250
P7B13=250
P7B14=250
P7B15=250
P7B16=250
P8B1=280
P8B2=280
P8B3=280
P8B4=280
P8B5=280
P8B6=280
P8B7=280
P8B8=280
P8B9=280
P8B10=280
P8B11=280
P8B12=280
P8B13=280
P8B14=280
P8B15=280
P8B16=280
P9B1=280
P9B2=280
P9B3=280
P9B4=280
P9B5=280
P9B6=280
P9B7=280
P9B8=280
P9B9=280
P9B10=280
P9B11=280
P9B12=280
P9B13=280
P9B14=280
P9B15=280
P9B16=280
P10B1=280
P10B2=280
P10B3=280
P10B4=280
P10B5=280
P10B6=280
P10B7=280
P10B8=280
P10B9=280
P10B10=280
P10B11=280
P10B12=280
P10B13=280
P10B14=280
P10B15=280
P10B16=280
P11B1=280
P11B2=280
P11B3=280
P11B4=280
P11B5=280
P11B6=280
P11B7=280
P11B8=280
P11B9=280
P11B10=280
P11B11=280
P11B12=280
P11B13=280
P11B14=280
P11B15=280
P11B16=280
P12B1=280
P12B2=280
P12B3=280
P12B4=280
P12B5=280
P12B6=280
P12B7=280
P12B8=280
P12B9=280
P12B10=280
P12B11=280
P12B12=280
P12B13=280
P12B14=280
P12B15=280
P12B16=280
P13B1=240
P13B2=240
P13B3=240
P13B4=240
P13B5=240
P13B6=240
P13B7=240
P13B8=240
P13B9=240
P13B10=240
P13B11=240
P13B12=240
P13B13=240
P13B14=200
P13B15=200
P13B16=200
P14B1=100
P14B2=100
P14B3=100
P14B4=100
P14B5=100
P14B6=100
P14B7=100
P14B8=100
P14B9=100
P14B10=100
P14B11=100
P14B12=100
P14B13=100
P14B14=100
P14B15=100
P14B16=100
P15B1=0
P15B2=0
P15B3=0
P15B4=0
P15B5=0
P15B6=0
P15B7=0
P15B8=0
P15B9=0
P15B10=0
P15B11=0
P15B12=-50
P15B13=-50
P15B14=-50
P15B15=-50
P15B16=-50
P16B1=0
P16B2=0
P16B3=0
P16B4=0
P16B5=0
P16B6=0
P16B7=0
P16B8=0
P16B9=0
P16B10=0
P16B11=0
P16B12=-100
P16B13=-100
P16B14=-100
P16B15=-100
P16B16=-100
P1C=3
P2C=5
P3C=8
P4C=10
P5C=12
P6C=15
P7C=19
P8C=22
P9C=25
P10C=32
P11C=44
P12C=50
P13C=60
P14C=75
P15C=80
P16C=100
[MAP3]
N=16
P1A=1000
P2A=1600
P3A=1800
P4A=2000
P5A=2500
P6A=3000
P7A=3500
P8A=4000
P9A=5000
P10A=6000
P11A=7000
P12A=7500
P13A=8000
P14A=8200
P15A=8300
P16A=10000
P1B1=130
P1B2=130
P1B3=150
P1B4=150
P1B5=150
P1B6=150
P1B7=150
P1B8=150
P1B9=150
P1B10=150
P1B11=150
P1B12=150
P1B13=150
P1B14=150
P1B15=150
P1B16=150
P2B1=130
P2B2=130
P2B3=150
P2B4=150
P2B5=150
P2B6=150
P2B7=150
P2B8=150
P2B9=150
P2B10=150
P2B11=150
P2B12=150
P2B13=150
P2B14=150
P2B15=150
P2B16=150
P3B1=130
P3B2=130
P3B3=150
P3B4=150
P3B5=150
P3B6=150
P3B7=150
P3B8=150
P3B9=150
P3B10=150
P3B11=150
P3B12=150
P3B13=150
P3B14=150
P3B15=150
P3B16=150
P4B1=130
P4B2=150
P4B3=150
P4B4=150
P4B5=150
P4B6=150
P4B7=150
P4B8=150
P4B9=150
P4B10=150
P4B11=150
P4B12=150
P4B13=150
P4B14=150
P4B15=150
P4B16=150
P5B1=130
P5B2=180
P5B3=180
P5B4=180
P5B5=180
P5B6=180
P5B7=180
P5B8=180
P5B9=180
P5B10=180
P5B11=180
P5B12=180
P5B13=180
P5B14=180
P5B15=180
P5B16=180
P6B1=180
P6B2=220
P6B3=220
P6B4=220
P6B5=220
P6B6=220
P6B7=220
P6B8=220
P6B9=220
P6B10=220
P6B11=220
P6B12=220
P6B13=220
P6B14=220
P6B15=220
P6B16=220
P7B1=250
P7B2=250
P7B3=250
P7B4=250
P7B5=250
P7B6=250
P7B7=250
P7B8=250
P7B9=250
P7B10=250
P7B11=250
P7B12=250
P7B13=250
P7B14=250
P7B15=250
P7B16=250
P8B1=280
P8B2=280
P8B3=280
P8B4=280
P8B5=280
P8B6=280
P8B7=280
P8B8=280
P8B9=280
P8B10=280
P8B11=280
P8B12=280
P8B13=280
P8B14=280
P8B15=280
P8B16=280
P9B1=280
P9B2=280
P9B3=280
P9B4=280
P9B5=280
P9B6=280
P9B7=280
P9B8=280
P9B9=280
P9B10=280
P9B11=280
P9B12=280
P9B13=280
P9B14=280
P9B15=280
P9B16=280
P10B1=280
P10B2=280
P10B3=280
P10B4=280
P10B5=280
P10B6=280
P10B7=280
P10B8=280
P10B9=280
P10B10=280
P10B11=280
P10B12=280
P10B13=280
P10B14=280
P10B15=280
P10B16=280
P11B1=280
P11B2=280
P11B3=280
P11B4=280
P11B5=280
P11B6=280
P11B7=280
P11B8=280
P11B9=280
P11B10=280
P11B11=280
P11B12=280
P11B13=280
P11B14=280
P11B15=280
P11B16=280
P12B1=280
P12B2=280
P12B3=280
P12B4=280
P12B5=280
P12B6=280
P12B7=280
P12B8=280
P12B9=280
P12B10=280
P12B11=280
P12B12=280
P12B13=280
P12B14=280
P12B15=280
P12B16=280
P13B1=240
P13B2=240
P13B3=240
P13B4=240
P13B5=240
P13B6=240
P13B7=240
P13B8=240
P13B9=240
P13B10=240
P13B11=240
P13B12=240
P13B13=240
P13B14=200
P13B15=200
P13B16=200
P14B1=100
P14B2=100
P14B3=100
P14B4=100
P14B5=100
P14B6=100
P14B7=100
P14B8=100
P14B9=100
P14B10=100
P14B11=100
P14B12=100
P14B13=100
P14B14=100
P14B15=100
P14B16=100
P15B1=0
P15B2=0
P15B3=0
P15B4=0
P15B5=0
P15B6=0
P15B7=0
P15B8=0
P15B9=0
P15B10=0
P15B11=0
P15B12=-50
P15B13=-50
P15B14=-50
P15B15=-50
P15B16=-50
P16B1=0
P16B2=0
P16B3=0
P16B4=0
P16B5=0
P16B6=0
P16B7=0
P16B8=0
P16B9=0
P16B10=0
P16B11=0
P16B12=-100
P16B13=-100
P16B14=-100
P16B15=-100
P16B16=-100
P1C=3
P2C=5
P3C=8
P4C=10
P5C=12
P6C=15
P7C=19
P8C=22
P9C=25
P10C=32
P11C=44
P12C=50
P13C=60
P14C=75
P15C=80
P16C=100
[MAP4]
N=6
P1A=3000
P2A=3500
P3A=5000
P4A=7400
P5A=8400
P6A=9000
P1B1=10
P1B2=10
P1B3=10
P1B4=10
P1B5=10
P1B6=10
P1B7=10
P1B8=10
P1B9=10
P1B10=10
P2B1=10
P2B2=10
P2B3=10
P2B4=10
P2B5=10
P2B6=10
P2B7=10
P2B8=10
P2B9=10
P2B10=10
P3B1=10
P3B2=10
P3B3=10
P3B4=10
P3B5=10
P3B6=10
P3B7=10
P3B8=10
P3B9=10
P3B10=10
P4B1=10
P4B2=10
P4B3=10
P4B4=10
P4B5=10
P4B6=10
P4B7=10
P4B8=10
P4B9=10
P4B10=10
P5B1=10
P5B2=10
P5B3=10
P5B4=10
P5B5=10
P5B6=10
P5B7=10
P5B8=10
P5B9=10
P5B10=10
P6B1=10
P6B2=10
P6B3=10
P6B4=10
P6B5=10
P6B6=10
P6B7=10
P6B8=10
P6B9=10
P6B10=10
P1C=0
P2C=3
P3C=5
P4C=10
P5C=20
P6C=30
P7C=40
P8C=60
P9C=80
P10C=100
[MAP5]
N=6
P1A=3000
P2A=3500
P3A=5000
P4A=7400
P5A=8400
P6A=9000
P1B1=0
P1B2=0
P1B3=0
P1B4=0
P1B5=0
P1B6=0
P1B7=0
P1B8=0
P1B9=0
P1B10=0
P2B1=0
P2B2=1
P2B3=1
P2B4=1
P2B5=1
P2B6=1
P2B7=1
P2B8=0
P2B9=1
P2B10=1
P3B1=0
P3B2=1
P3B3=1
P3B4=1
P3B5=1
P3B6=1
P3B7=1
P3B8=0
P3B9=1
P3B10=1
P4B1=0
P4B2=1
P4B3=1
P4B4=1
P4B5=1
P4B6=1
P4B7=1
P4B8=0
P4B9=1
P4B10=1
P5B1=0
P5B2=1
P5B3=1
P5B4=1
P5B5=1
P5B6=1
P5B7=1
P5B8=0
P5B9=1
P5B10=1
P6B1=0
P6B2=0
P6B3=0
P6B4=0
P6B5=0
P6B6=0
P6B7=0
P6B8=0
P6B9=0
P6B10=0
P1C=0
P2C=3
P3C=5
P4C=10
P5C=20
P6C=30
P7C=40
P8C=60
P9C=80
P10C=100
[MAP6]
N=6
P1A=3000
P2A=3500
P3A=5000
P4A=7400
P5A=8400
P6A=9000
P1B1=1
P1B2=1
P1B3=1
P1B4=1
P1B5=1
P1B6=1
P1B7=1
P1B8=1
P1B9=1
P1B10=1
P2B1=1
P2B2=1
P2B3=1
P2B4=1
P2B5=1
P2B6=1
P2B7=1
P2B8=1
P2B9=1
P2B10=1
P3B1=1
P3B2=1
P3B3=1
P3B4=1
P3B5=1
P3B6=1
P3B7=1
P3B8=1
P3B9=1
P3B10=1
P4B1=1
P4B2=1
P4B3=1
P4B4=1
P4B5=1
P4B6=1
P4B7=1
P4B8=1
P4B9=1
P4B10=1
P5B1=1
P5B2=1
P5B3=1
P5B4=1
P5B5=1
P5B6=1
P5B7=1
P5B8=1
P5B9=1
P5B10=1
P6B1=1
P6B2=1
P6B3=1
P6B4=1
P6B5=1
P6B6=1
P6B7=1
P6B8=1
P6B9=1
P6B10=1
P1C=0
P2C=3
P3C=5
P4C=10
P5C=20
P6C=30
P7C=40
P8C=60
P9C=80
P10C=100
[MAP7]
N=6
P1A=3000
P2A=3500
P3A=5000
P4A=7400
P5A=8400
P6A=9000
P1B1=0
P1B2=0
P1B3=0
P1B4=0
P1B5=0
P1B6=0
P1B7=0
P1B8=0
P1B9=0
P1B10=0
P2B1=0
P2B2=0
P2B3=0
P2B4=0
P2B5=0
P2B6=0
P2B7=0
P2B8=0
P2B9=0
P2B10=0
P3B1=0
P3B2=0
P3B3=0
P3B4=0
P3B5=0
P3B6=0
P3B7=0
P3B8=0
P3B9=0
P3B10=0
P4B1=0
P4B2=0
P4B3=0
P4B4=0
P4B5=0
P4B6=0
P4B7=0
P4B8=0
P4B9=0
P4B10=0
P5B1=0
P5B2=0
P5B3=0
P5B4=0
P5B5=0
P5B6=0
P5B7=0
P5B8=0
P5B9=0
P5B10=0
P6B1=0
P6B2=0
P6B3=0
P6B4=0
P6B5=0
P6B6=0
P6B7=0
P6B8=0
P6B9=0
P6B10=0
P1C=0
P2C=3
P3C=5
P4C=10
P5C=20
P6C=30
P7C=40
P8C=60
P9C=80
P10C=100
[MAP8]
N=16
P1A=1200
P2A=1500
P3A=2000
P4A=3500
P5A=4000
P6A=4500
P7A=5000
P8A=5500
P9A=6000
P10A=6500
P11A=7000
P12A=7500
P13A=8000
P14A=8500
P15A=9000
P16A=11000
P1B1=1
P1B2=1
P1B3=1
P1B4=1
P1B5=1
P1B6=1
P1B7=1
P1B8=1
P1B9=1
P1B10=1
P1B11=1
P1B12=1
P1B13=1
P1B14=1
P1B15=1
P1B16=1
P2B1=1
P2B2=1
P2B3=1
P2B4=1
P2B5=1
P2B6=1
P2B7=1
P2B8=1
P2B9=1
P2B10=1
P2B11=1
P2B12=1
P2B13=1
P2B14=1
P2B15=1
P2B16=1
P3B1=1
P3B2=1
P3B3=1
P3B4=1
P3B5=1
P3B6=1
P3B7=1
P3B8=1
P3B9=1
P3B10=1
P3B11=1
P3B12=1
P3B13=1
P3B14=1
P3B15=1
P3B16=1
P4B1=1
P4B2=1
P4B3=1
P4B4=1
P4B5=1
P4B6=1
P4B7=1
P4B8=1
P4B9=1
P4B10=1
P4B11=1
P4B12=1
P4B13=1
P4B14=1
P4B15=1
P4B16=1
P5B1=1
P5B2=1
P5B3=1
P5B4=1
P5B5=1
P5B6=1
P5B7=1
P5B8=1
P5B9=1
P5B10=1
P5B11=1
P5B12=1
P5B13=1
P5B14=1
P5B15=1
P5B16=1
P6B1=1
P6B2=1
P6B3=1
P6B4=1
P6B5=1
P6B6=1
P6B7=1
P6B8=1
P6B9=1
P6B10=1
P6B11=1
P6B12=1
P6B13=1
P6B14=1
P6B15=1
P6B16=1
P7B1=60
P7B2=50
P7B3=50
P7B4=50
P7B5=30
P7B6=30
P7B7=30
P7B8=1
P7B9=1
P7B10=1
P7B11=1
P7B12=1
P7B13=1
P7B14=1
P7B15=1
P7B16=1
P8B1=100
P8B2=50
P8B3=70
P8B4=70
P8B5=60
P8B6=50
P8B7=50
P8B8=1
P8B9=1
P8B10=1
P8B11=1
P8B12=1
P8B13=1
P8B14=1
P8B15=1
P8B16=1
P9B1=100
P9B2=50
P9B3=60
P9B4=60
P9B5=60
P9B6=50
P9B7=50
P9B8=1
P9B9=1
P9B10=1
P9B11=1
P9B12=1
P9B13=1
P9B14=1
P9B15=1
P9B16=1
P10B1=100
P10B2=50
P10B3=50
P10B4=50
P10B5=50
P10B6=50
P10B7=50
P10B8=1
P10B9=1
P10B10=1
P10B11=1
P10B12=1
P10B13=1
P10B14=1
P10B15=10
P10B16=10
P11B1=100
P11B2=50
P11B3=40
P11B4=40
P11B5=40
P11B6=50
P11B7=50
P11B8=1
P11B9=1
P11B10=1
P11B11=1
P11B12=1
P11B13=1
P11B14=1
P11B15=30
P11B16=30
P12B1=100
P12B2=1
P12B3=1
P12B4=1
P12B5=1
P12B6=1
P12B7=1
P12B8=1
P12B9=1
P12B10=1
P12B11=1
P12B12=1
P12B13=1
P12B14=1
P12B15=30
P12B16=30
P13B1=100
P13B2=1
P13B3=1
P13B4=1
P13B5=1
P13B6=1
P13B7=1
P13B8=1
P13B9=1
P13B10=1
P13B11=1
P13B12=1
P13B13=1
P13B14=30
P13B15=50
P13B16=50
P14B1=1
P14B2=1
P14B3=1
P14B4=1
P14B5=1
P14B6=1
P14B7=1
P14B8=1
P14B9=1
P14B10=1
P14B11=1
P14B12=1
P14B13=1
P14B14=50
P14B15=50
P14B16=50
P15B1=1
P15B2=1
P15B3=1
P15B4=1
P15B5=1
P15B6=1
P15B7=1
P15B8=1
P15B9=1
P15B10=1
P15B11=1
P15B12=1
P15B13=1
P15B14=50
P15B15=50
P15B16=50
P16B1=1
P16B2=1
P16B3=1
P16B4=1
P16B5=1
P16B6=1
P16B7=1
P16B8=1
P16B9=1
P16B10=1
P16B11=1
P16B12=1
P16B13=1
P16B14=1
P16B15=1
P16B16=1
P1C=1
P2C=3
P3C=5
P4C=10
P5C=15
P6C=20
P7C=25
P8C=30
P9C=35
P10C=40
P11C=50
P12C=60
P13C=70
P14C=80
P15C=90
P16C=100
[MAP9]
N=16
P1A=1200
P2A=1500
P3A=2000
P4A=3500
P5A=4000
P6A=4500
P7A=5000
P8A=5500
P9A=6000
P10A=6500
P11A=7000
P12A=7500
P13A=8000
P14A=8500
P15A=9000
P16A=11000
P1B1=1
P1B2=1
P1B3=1
P1B4=1
P1B5=1
P1B6=1
P1B7=1
P1B8=1
P1B9=1
P1B10=1
P1B11=1
P1B12=1
P1B13=1
P1B14=1
P1B15=1
P1B16=1
P2B1=1
P2B2=1
P2B3=1
P2B4=1
P2B5=1
P2B6=1
P2B7=1
P2B8=1
P2B9=1
P2B10=1
P2B11=1
P2B12=1
P2B13=1
P2B14=1
P2B15=1
P2B16=1
P3B1=1
P3B2=1
P3B3=1
P3B4=1
P3B5=1
P3B6=1
P3B7=1
P3B8=1
P3B9=1
P3B10=1
P3B11=1
P3B12=1
P3B13=1
P3B14=1
P3B15=1
P3B16=1
P4B1=1
P4B2=1
P4B3=1
P4B4=1
P4B5=1
P4B6=1
P4B7=1
P4B8=1
P4B9=1
P4B10=1
P4B11=1
P4B12=1
P4B13=1
P4B14=1
P4B15=1
P4B16=1
P5B1=1
P5B2=1
P5B3=1
P5B4=1
P5B5=1
P5B6=1
P5B7=1
P5B8=1
P5B9=1
P5B10=1
P5B11=1
P5B12=1
P5B13=1
P5B14=1
P5B15=1
P5B16=1
P6B1=1
P6B2=1
P6B3=1
P6B4=1
P6B5=1
P6B6=1
P6B7=1
P6B8=1
P6B9=1
P6B10=1
P6B11=1
P6B12=1
P6B13=1
P6B14=1
P6B15=1
P6B16=1
P7B1=60
P7B2=50
P7B3=50
P7B4=50
P7B5=30
P7B6=30
P7B7=30
P7B8=1
P7B9=1
P7B10=1
P7B11=1
P7B12=1
P7B13=1
P7B14=1
P7B15=1
P7B16=1
P8B1=100
P8B2=50
P8B3=70
P8B4=70
P8B5=60
P8B6=50
P8B7=50
P8B8=1
P8B9=1
P8B10=1
P8B11=1
P8B12=1
P8B13=1
P8B14=1
P8B15=1
P8B16=1
P9B1=100
P9B2=50
P9B3=60
P9B4=60
P9B5=60
P9B6=50
P9B7=50
P9B8=1
P9B9=1
P9B10=1
P9B11=1
P9B12=1
P9B13=1
P9B14=1
P9B15=1
P9B16=1
P10B1=100
P10B2=50
P10B3=50
P10B4=50
P10B5=50
P10B6=50
P10B7=50
P10B8=1
P10B9=1
P10B10=1
P10B11=1
P10B12=1
P10B13=1
P10B14=1
P10B15=10
P10B16=10
P11B1=100
P11B2=50
P11B3=40
P11B4=40
P11B5=40
P11B6=50
P11B7=50
P11B8=1
P11B9=1
P11B10=1
P11B11=1
P11B12=1
P11B13=1
P11B14=1
P11B15=30
P11B16=30
P12B1=100
P12B2=1
P12B3=1
P12B4=1
P12B5=1
P12B6=1
P12B7=1
P12B8=1
P12B9=1
P12B10=1
P12B11=1
P12B12=1
P12B13=1
P12B14=1
P12B15=30
P12B16=30
P13B1=100
P13B2=1
P13B3=1
P13B4=1
P13B5=1
P13B6=1
P13B7=1
P13B8=1
P13B9=1
P13B10=1
P13B11=1
P13B12=1
P13B13=1
P13B14=30
P13B15=50
P13B16=50
P14B1=1
P14B2=1
P14B3=1
P14B4=1
P14B5=1
P14B6=1
P14B7=1
P14B8=1
P14B9=1
P14B10=1
P14B11=1
P14B12=1
P14B13=1
P14B14=50
P14B15=50
P14B16=50
P15B1=1
P15B2=1
P15B3=1
P15B4=1
P15B5=1
P15B6=1
P15B7=1
P15B8=1
P15B9=1
P15B10=1
P15B11=1
P15B12=1
P15B13=1
P15B14=50
P15B15=50
P15B16=50
P16B1=1
P16B2=1
P16B3=1
P16B4=1
P16B5=1
P16B6=1
P16B7=1
P16B8=1
P16B9=1
P16B10=1
P16B11=1
P16B12=1
P16B13=1
P16B14=1
P16B15=1
P16B16=1
P1C=1
P2C=3
P3C=5
P4C=10
P5C=15
P6C=20
P7C=25
P8C=30
P9C=35
P10C=40
P11C=50
P12C=60
P13C=70
P14C=80
P15C=90
P16C=100
[MAP10]
N=6
P1A=1600
P2A=1800
P3A=2000
P4A=2500
P5A=5000
P6A=6000
P1B1=0
P1B2=0
P1B3=0
P1B4=0
P1B5=0
P1B6=0
P1B7=0
P1B8=0
P2B1=0
P2B2=0
P2B3=0
P2B4=0
P2B5=0
P2B6=0
P2B7=0
P2B8=0
P3B1=0
P3B2=0
P3B3=0
P3B4=0
P3B5=0
P3B6=0
P3B7=0
P3B8=0
P4B1=0
P4B2=0
P4B3=0
P4B4=0
P4B5=0
P4B6=0
P4B7=0
P4B8=0
P5B1=0
P5B2=0
P5B3=0
P5B4=0
P5B5=0
P5B6=0
P5B7=0
P5B8=0
P6B1=0
P6B2=0
P6B3=0
P6B4=0
P6B5=0
P6B6=0
P6B7=0
P6B8=0
P1C=-20
P2C=18
P3C=20
P4C=30
P5C=50
P6C=70
P7C=100
P8C=120
[MAP11]
N=6
P1A=1600
P2A=1800
P3A=2000
P4A=2500
P5A=5000
P6A=6000
P1B1=0
P1B2=0
P1B3=0
P1B4=0
P1B5=0
P1B6=0
P1B7=0
P1B8=0
P2B1=0
P2B2=0
P2B3=0
P2B4=0
P2B5=0
P2B6=0
P2B7=0
P2B8=0
P3B1=0
P3B2=0
P3B3=0
P3B4=0
P3B5=0
P3B6=0
P3B7=0
P3B8=0
P4B1=0
P4B2=0
P4B3=0
P4B4=0
P4B5=0
P4B6=0
P4B7=0
P4B8=0
P5B1=0
P5B2=0
P5B3=0
P5B4=0
P5B5=0
P5B6=0
P5B7=0
P5B8=0
P6B1=0
P6B2=0
P6B3=0
P6B4=0
P6B5=0
P6B6=0
P6B7=0
P6B8=0
P1C=-20
P2C=18
P3C=20
P4C=30
P5C=50
P6C=70
P7C=100
P8C=120
[MAP12]
N=16
P1A=199
P1B=-30
P2A=167
P2B=-20
P3A=139
P3B=-10
P4A=112
P4B=0
P5A=95
P5B=10
P6A=81
P6B=20
P7A=73
P7B=30
P8A=68
P8B=40
P9A=64
P9B=50
P10A=58
P10B=60
P11A=56
P11B=70
P12A=53
P12B=80
P13A=50
P13B=90
P14A=49
P14B=100
P15A=46
P15B=120
P16A=45
P16B=121
[MAP13]
N=6
P1A=1600
P2A=1800
P3A=2000
P4A=2500
P5A=5000
P6A=6000
P1B1=80
P1B2=80
P1B3=50
P1B4=50
P1B5=40
P1B6=0
P1B7=0
P1B8=0
P2B1=80
P2B2=80
P2B3=50
P2B4=50
P2B5=20
P2B6=0
P2B7=0
P2B8=0
P3B1=80
P3B2=80
P3B3=50
P3B4=0
P3B5=0
P3B6=-40
P3B7=-50
P3B8=-50
P4B1=80
P4B2=80
P4B3=50
P4B4=0
P4B5=0
P4B6=0
P4B7=0
P4B8=0
P5B1=30
P5B2=30
P5B3=30
P5B4=0
P5B5=0
P5B6=0
P5B7=0
P5B8=0
P6B1=0
P6B2=0
P6B3=0
P6B4=0
P6B5=0
P6B6=0
P6B7=0
P6B8=0
P1C=-20
P2C=18
P3C=20
P4C=30
P5C=50
P6C=70
P7C=100
P8C=120
[MAP14]
N=6
P1A=1600
P2A=1800
P3A=2000
P4A=2500
P5A=5000
P6A=6000
P1B1=-100
P1B2=-100
P1B3=-100
P1B4=-100
P1B5=-100
P1B6=-100
P1B7=0
P1B8=0
P2B1=-100
P2B2=-100
P2B3=-100
P2B4=-100
P2B5=-50
P2B6=0
P2B7=0
P2B8=0
P3B1=-100
P3B2=-100
P3B3=-100
P3B4=-50
P3B5=0
P3B6=0
P3B7=0
P3B8=0
P4B1=-100
P4B2=-100
P4B3=0
P4B4=0
P4B5=0
P4B6=0
P4B7=0
P4B8=0
P5B1=-100
P5B2=-100
P5B3=0
P5B4=0
P5B5=0
P5B6=0
P5B7=0
P5B8=0
P6B1=-100
P6B2=-100
P6B3=0
P6B4=0
P6B5=0
P6B6=0
P6B7=0
P6B8=0
P1C=-20
P2C=18
P3C=20
P4C=30
P5C=50
P6C=70
P7C=100
P8C=120
[MAP15]
N=16
P1A=251
P1B=-40
P2A=243
P2B=-20
P3A=223
P3B=0
P4A=206
P4B=10
P5A=185
P5B=20
P6A=161
P6B=30
P7A=136
P7B=40
P8A=111
P8B=50
P9A=88
P9B=60
P10A=69
P10B=70
P11A=54
P11B=80
P12A=42
P12B=90
P13A=32
P13B=100
P14A=25
P14B=120
P15A=12
P15B=140
P16A=6
P16B=170
[MAP16]
N=8
P1A=-10
P1B=0
P2A=15
P2B=0
P3A=18
P3B=50
P4A=20
P4B=100
P5A=80
P5B=100
P6A=90
P6B=50
P7A=110
P7B=50
P8A=130
P8B=50
[MAP17]
N=8
P1A=-10
P1B=0
P2A=15
P2B=0
P3A=18
P3B=0
P4A=20
P4B=0
P5A=80
P5B=0
P6A=90
P6B=0
P7A=110
P7B=0
P8A=130
P8B=0
[MAP18]
N=6
P1A=3000
P1B=0
P2A=3500
P2B=0
P3A=4500
P3B=0
P4A=6300
P4B=0
P5A=7000
P5B=0
P6A=8000
P6B=0
[MAP19]
N=6
P1A=3000
P1B=0
P2A=3500
P2B=0
P3A=4500
P3B=0
P4A=6300
P4B=0
P5A=7000
P5B=0
P6A=8000
P6B=0
Senest rettet af freddyjensen 28. oktober 2023 12:53, rettet i alt 3 gange.
Re: Vga N1 30 Km/t Ecu Hjælp Euro 4
Indlæg af scootergrisen »
Du er den første herinde der har gjort det og skrevet om det så fortæl og vis gerne hvordan du har gjort det.
Hvad vil du har opsat?
Du kan formodentligt bruge softwaren til at indstille de forskellige værdier så du ikke behøver redigere i tekstfilen.
freddyjensen
jeg har Prøvet at ændre filen og der fik jeg den til at tage 10000 Omdrejninger hvor den kun kunne tage 8000 på støttefod den køre Ca 55 men den opsætning jeg har lavet på den.
Senest rettet af freddyjensen 29. oktober 2023 07:35, rettet i alt 1 gang.
Hvad vil du gerne ændre?
freddyjensen
Hvis der var en der havde købt en Ubegrænset ECU som jeg kunne kigge i mod betaling. Jeg har selv formodet at få det op på 10000 Omdrejninger i mod 8000 orginal så jeg ved ikke meget om parmeterne i filen uden det jeg har sjusset mig frem til.
Du kan oprette et nyt emne om det med en ubegrænset ECU.
Har du set den her?
Kode: Vælg alt
PAR70_DES=Speed_Max
PAR70_VAL=44
freddyjensen
Men for at den skal kunne tage flere omdrejninger er det ikke nok at ændre 66 og 70 man skal ændre alle værdier fra 8000 til 10000 og alle 9000 til 10000 osv ellers vil den ikke tage flere omdrejninger end normal.
PAR66_VAL=8500 Ændret til 10000
PAR70_DES=Speed_Max
PAR70_VAL=44 Ændret til 0
Aner det ikke der er ikke så mange der har skrevet om det endnu.
Jeg har samlet noget om det på:
viewtopic.php?f=3&t=3996
viewtopic.php?f=3&t=3387
Er dataene i kodeblokken de originale data fra før du lavede ændringer?
Så kan vi lave en liste og sådan nogle map-filer.
freddyjensen
Ja det er den originale data Jeg kan se der er lidt forskel på data i det ene opslag du linkede så tror jeg vil prøve de indstillinger i min ECU.
Måske du kan bruge det her fra en fil kaldet CLC_V504.ecs.
Det er åbenbart strenge der bruges i Deuss Service Tool.
Kode: Vælg alt
[HEADER]
ECS_TYPE=CLC_V504
[LABELS_DATA]
CONFIG=ECS_CLC
LAB_DATA_1=RPM
LAB_DATA_2=dRPM/dt
LAB_DATA_3=Advance
LAB_DATA_4=dTPS/dt (bit)
LAB_DATA_5=Battery (V)
LAB_DATA_6=Dwell time (ms)
LAB_DATA_7=Acc
LAB_DATA_8=Dec
LAB_DATA_9=Active Map
LAB_DATA_10=O2 Sensor (mV)
LAB_DATA_11=Engine T (°C)
LAB_DATA_12=TPS (%)
LAB_DATA_13=CLC ADJ AIR (%)
LAB_DATA_14=°Acc
LAB_DATA_15=°Dec
LAB_DATA_16=AIR PWM (%)
LAB_DATA_17=RPM CUT OFF
[PARAMETERS]
N=111
NUM_PAR_TPS_MIN=110
NUM_PAR_TPS_MAX=111
PAR1_DES=ID_MapFile
PAR2_DES=Th_Type
PAR29_DES=Not_Used
PAR30_DES=Not_Used
PAR31_DES=Not_Used
PAR32_DES=Not_Used
PAR33_DES=Not_Used
PAR34_DES=Not_Used
PAR53_DES=Air_En
PAR55_DES=CLC_En
PAR59_DES=TPS_En
PAR70_DES=Speed_Max
[MAPS]
NUM_ARGUMENT_MAP=8
NUM_MAP=19
[MAP_MENULIST]
M0=Dwell time
M0_EN=TRUE
SUB_M0=0
M1=Advance
M1_EN=TRUE
SUB_M1=2
SUB_M1_SM0=Basic
SUB_M1_SM1=Tune Up
M2=Lambda
M2_EN=TRUE
SUB_M2=4
SUB_M2_SM0=IsoStep
SUB_M2_SM1=DeltaStep
SUB_M2_SM2=IsoIncr
SUB_M2_SM3=DeltaIncr
M3=Air valve
M3_EN=TRUE
SUB_M3=2
SUB_M3_SM0=Basic
SUB_M3_SM1=Tune Up
M4=Environment temperature
M4_EN=FALSE
SUB_M4=3
SUB_M4_SM0=Advance
SUB_M4_SM1=Air
SUB_M4_SM2=NTC
M5=Engine temperature
M5_EN=TRUE
SUB_M5=3
SUB_M5_SM0=Advance
SUB_M5_SM1=Air
SUB_M5_SM2=NTC
M6=ASD starter
M6_EN=TRUE
SUB_M6=2
SUB_M6_SM0=PWM
SUB_M6_SM1=Delay
M7=Emission
M7_EN=TRUE
SUB_M7=2
SUB_M7_SM0=Step
SUB_M7_SM1=Incr
[MAP1]
NAME=1 Dwell time
NUMOFPOINT=16
NUMOFZPOINT=0
IS_A_3DMAP=0
X_DESCRIPTION=Battery voltage (0.1V)
SEEK_VAR_NAME=VBATT
Z_SEEK_VAR_NAME=NONE
X_MIN=40
X_MAX=200
X_SCROLL_INVERT=FALSE
X_IS%VALUE=0
z_IS%VALUE=0
Y_DESCRIPTION=Dwell time (0.1ms)
Y_MIN=5
Y_MAX=200
XSYNC_LEV=0
[MAP2]
NAME=2 Advance - Basic
NUMOFPOINT=16
NUMOFZPOINT=16
IS_A_3DMAP=1
X_DESCRIPTION=Engine speed (RPM)
SEEK_VAR_NAME=RPM
Z_SEEK_VAR_NAME=TPS
X_MIN=250
X_MAX=15000
X_IS%VALUE=0
z_IS%VALUE=1
Y_DESCRIPTION=Spark advance (0.1°)
Y_MIN=0
Y_MAX=600
Z_DESCRIPTION=TPS (%)
Z_MIN=0
Z_MAX=100
XSYNC_LEV=1
[MAP3]
NAME=3 Advance - Tune Up
NUMOFPOINT=16
NUMOFZPOINT=16
IS_A_3DMAP=1
SEEK_VAR_NAME=RPM
Z_SEEK_VAR_NAME=TPS
X_MIN=250
X_MAX=15000
X_IS%VALUE=0
z_IS%VALUE=1
Y_MIN=0
Y_MAX=600
Z_MIN=0
Z_MAX=100
XSYNC_LEV=1
[MAP4]
NAME=4 Lambda - Iso step
NUMOFPOINT=6
NUMOFZPOINT=10
IS_A_3DMAP=1
SEEK_VAR_NAME=RPM
Z_SEEK_VAR_NAME=TPS
X_MIN=250
X_MAX=15000
X_IS%VALUE=0
z_IS%VALUE=1
Y_DESCRIPTION=Air correction (%)
Y_MIN=0
Y_MAX=100
Z_MIN=0
Z_MAX=100
XSYNC_LEV=2
[MAP5]
NAME=5 Lambda - Delta step
NUMOFPOINT=6
NUMOFZPOINT=10
IS_A_3DMAP=1
SEEK_VAR_NAME=RPM
Z_SEEK_VAR_NAME=TPS
X_MIN=250
X_MAX=15000
X_IS%VALUE=0
z_IS%VALUE=1
Y_MIN=0
Y_MAX=100
Z_MIN=0
Z_MAX=100
XSYNC_LEV=2
[MAP6]
NAME=6 Lambda - Iso incr
NUMOFPOINT=6
NUMOFZPOINT=10
IS_A_3DMAP=1
SEEK_VAR_NAME=RPM
Z_SEEK_VAR_NAME=TPS
X_MIN=250
X_MAX=15000
X_IS%VALUE=0
z_IS%VALUE=1
Y_MIN=0
Y_MAX=100
Z_MIN=0
Z_MAX=100
XSYNC_LEV=2
[MAP7]
NAME=7 Lambda - Delta incr
NUMOFPOINT=6
NUMOFZPOINT=10
IS_A_3DMAP=1
SEEK_VAR_NAME=RPM
Z_SEEK_VAR_NAME=TPS
X_MIN=250
X_MAX=15000
X_IS%VALUE=0
z_IS%VALUE=1
Y_MIN=0
Y_MAX=100
Z_MIN=0
Z_MAX=100
XSYNC_LEV=2
[MAP8]
NAME=8 Air - Basic
NUMOFPOINT=16
NUMOFZPOINT=16
IS_A_3DMAP=1
SEEK_VAR_NAME=RPM
Z_SEEK_VAR_NAME=TPS
X_MIN=250
X_MAX=15000
X_IS%VALUE=0
z_IS%VALUE=1
Y_DESCRIPTION=PWM (%)
Y_MIN=0
Y_MAX=100
Z_MIN=0
Z_MAX=100
XSYNC_LEV=3
[MAP9]
NAME=9 Air - Tune Up
NUMOFPOINT=16
NUMOFZPOINT=16
IS_A_3DMAP=1
SEEK_VAR_NAME=RPM
Z_SEEK_VAR_NAME=TPS
X_MIN=250
X_MAX=15000
X_IS%VALUE=0
z_IS%VALUE=1
Y_MIN=0
Y_MAX=100
Z_MIN=0
Z_MAX=100
XSYNC_LEV=3
[MAP10]
NAME=10 Air temperature - Advance adjust
NUMOFPOINT=6
NUMOFZPOINT=8
IS_A_3DMAP=1
SEEK_VAR_NAME=RPM
Z_SEEK_VAR_NAME=TAMB
X_MIN=250
X_MAX=15000
X_IS%VALUE=0
z_IS%VALUE=0
Y_DESCRIPTION=Spark advance adjust (0.1°)
Y_MIN=-400
Y_MAX=400
Z_MIN=-80
Z_MAX=200
XSYNC_LEV=4
[MAP11]
NAME=11 Air temperature - Air PWM adjust
NUMOFPOINT=6
NUMOFZPOINT=8
IS_A_3DMAP=1
SEEK_VAR_NAME=RPM
X_MIN=250
X_MAX=15000
X_IS%VALUE=0
z_IS%VALUE=0
Y_DESCRIPTION=Air PWM adjust (%)
Y_MIN=-100
Y_MAX=100
Z_MIN=-80
Z_MAX=200
XSYNC_LEV=4
[MAP12]
NAME=12 Air temperature - NTC
NUMOFPOINT=16
NUMOFZPOINT=0
IS_A_3DMAP=0
X_DESCRIPTION=Temperature (°C)
SEEK_VAR_NAME=TAMB_NTC
X_MIN=0
X_MAX=256
X_SCROLL_INVERT=TRUE
X_IS%VALUE=0
z_IS%VALUE=0
Y_DESCRIPTION=Digital value (bit)
Y_MIN=-80
Y_MAX=200
XSYNC_LEV=5
[MAP13]
NAME=13 Engine temperature - Advance adjust
NUMOFPOINT=6
NUMOFZPOINT=8
IS_A_3DMAP=1
SEEK_VAR_NAME=RPM
Z_SEEK_VAR_NAME=TENG
X_MIN=250
X_MAX=15000
X_IS%VALUE=0
z_IS%VALUE=0
Y_MIN=-400
Y_MAX=400
Z_MIN=-80
Z_MAX=200
XSYNC_LEV=4
[MAP14]
NAME=14 Engine temperature - Air
NUMOFPOINT=6
NUMOFZPOINT=8
IS_A_3DMAP=1
SEEK_VAR_NAME=RPM
X_MIN=250
X_MAX=15000
X_IS%VALUE=0
z_IS%VALUE=0
Y_MIN=-100
Y_MAX=100
Z_MIN=-80
Z_MAX=200
XSYNC_LEV=4
[MAP15]
NAME=15 Engine Temperature - NTC
NUMOFPOINT=16
NUMOFZPOINT=0
IS_A_3DMAP=0
SEEK_VAR_NAME=TENG_NTC
X_MIN=0
X_MAX=256
X_IS%VALUE=0
z_IS%VALUE=0
Y_MIN=-80
Y_MAX=200
XSYNC_LEV=7
[MAP16]
NAME=16 ASD starter - Engine temperature
NUMOFPOINT=8
NUMOFZPOINT=0
IS_A_3DMAP=0
SEEK_VAR_NAME=TENG
X_MIN=-100
X_MAX=32767
X_IS%VALUE=0
z_IS%VALUE=0
Y_MIN=0
Y_MAX=100
XSYNC_LEV=8
[MAP17]
NAME=17 ASD starter - Delay
NUMOFPOINT=8
NUMOFZPOINT=0
IS_A_3DMAP=0
SEEK_VAR_NAME=TENG
X_MIN=-100
X_MAX=32767
X_IS%VALUE=0
z_IS%VALUE=0
Y_DESCRIPTION=Delay (s)
Y_MIN=0
Y_MAX=1200
XSYNC_LEV=8
[MAP18]
NAME=18 Emission - Step
NUMOFPOINT=6
NUMOFZPOINT=0
IS_A_3DMAP=0
SEEK_VAR_NAME=RPM
X_MIN=250
X_MAX=15000
X_IS%VALUE=0
z_IS%VALUE=0
Y_MIN=-100
Y_MAX=100
XSYNC_LEV=9
[MAP19]
NAME=19 Emission - Incr
NUMOFPOINT=6
NUMOFZPOINT=0
IS_A_3DMAP=0
SEEK_VAR_NAME=RPM
X_MIN=250
X_MAX=15000
X_IS%VALUE=0
z_IS%VALUE=0
Y_MIN=-100
Y_MAX=100
XSYNC_LEV=9
