Re: Nyhed: Ugbest Cabin-E3 (elektrisk kabinescooter)
: 21. august 2022 10:58
Motordæksel yderst inkl. leje, CabEasy
https://scootergrisen.org/forum/
PERSINO DC-DC非隔高转换器
知乐途专用
输入电压: DC60/72V
输出电压: DC13.8±0.3V 答入线: 正红 负黑
峰值电流: 25±2A 输出线: 正黄 负黑
输出功率: 300W 控制线: 细绿
双路输出: 高压控制 辅助输出: 亚线
温州帕萨诺电子科技有跟公司制造
[stregkode]
PSN-2305
PERSINO DC-DC non-height isolation converter
Dedicated to Zhileto
Input voltage: DC60/72V
Output Voltage: DC13.8±0.3V Answering line: positive red negative black
Peak current: 25±2A Output line: positive yellow negative black
Output power: 300W Control line: Fine green
Dual outputs: high voltage control Auxiliary output: subwire
Wenzhou Pasano Electronic Technology has been manufactured with the company
[stregkode]
PSN-2305
PERSINO DC-DC Non-Isolated Converters
Specialized for Zhiluotou
Output Voltage: DC13.8±0.3V Input Line: Positive Red Negative Black
Peak Current: 25±2A Output Line: Positive Yellow Negative Black
Output Power: 300W Control Wire: Thin Green
Dual Output: High Voltage Control Auxiliary Output: Sub Wire
Wenzhou Pasano Electronic Technology Co.
[stregkode]
PSN-2305
Batteri til Ive-Car Plus+.Lithium Battery Charge
Model: AKL71.4V15A
Input Voltage: AC176V-264V
Battery type: Li-ion
Maximum Out Voltage: 71.4V
Maximum Out Current: 15A
Charger Indicator
* Red light flashing: During charging.
* Green light on: Full battery.
* Alternating red and green: Refer to the malfunction status table.
Made in China
2023-06
Matters Need Attention
* For indoor use only.
* Do not charge in rainy and humid places.
* High voltage inside machine.
* Amateur technicians cannot open the box.
ISO ISO IATF
14001 9001 16949
Ive-Car Plus+ sælges åbenbart et to udgaver med forskellig batterikapacitet. En udgave med ét batteri og en udgave med to batterier.KWSD-17S50AhSKT3000WH-202307050029
T60V50AH
