Unlocking the Gate: The Gate Control Room
Once all four security codes have been collected, players must make their way to the Gate Control Room-a dimly lit console room located just to the east of Checkpoint. This room is equipped with four terminals, each corresponding to one of the four codes. To unlock the gate, players must input the codes in any order, ensuring that they match the symbols on ARC Raiders BluePrints each terminal. Once all four codes are entered correctly, the gate opens, and a green light confirms the successful unlock.
However, unlocking the gate doesn't guarantee an easy escape. Players must still navigate the remaining dangers of the map, including the presence of rival squads and lurking environmental hazards.
Strategies for Victory
Mastering the Locked Gate modifier requires a balance of skill, teamwork, and strategy. Below are a few tips to increase your chances of success:
Squad Synergy
It's crucial to assign roles within your squad. One player can focus on looting the easier codes at Raider's Refuge and Reinforced Reception, while two players take on the heavier fights at Pilgrim's Peak and Ancient Fort. By rotating through these roles and keeping an eye on squad health, you'll improve your chances of successfully collecting all the codes.
Gear Loadout
Choosing the right gear is key to survival. Suppressors are essential for stealth, allowing you to loot and navigate without drawing unwanted attention. Bringing defibrillators is a smart move in case you or a squadmate steps on a mine or falls victim to enemy fire. EMP grenades can be used to disable Rocketeers or automated turrets, giving you a strategic edge in tough firefights.
Timer Management
Time management is critical in the Locked Gate modifier. Prioritize collecting the codes at Raider's Refuge and Reinforced Reception first, as they are closer to your starting point. Use vehicles sparingly, as ARC drones actively hunt them down, but they can be useful for fast travel when needed.
Extraction Flexibility
If you manage to collect partial codes, it's still possible to extract with what you've gathered. Consider using alternate exfil routes, such as sewers or rooftops, as backups in case your primary extraction point becomes too dangerous.
Scav Intel
Listen for rival chatter and pay attention to enemy movement. Contested sites, such as Pilgrim's Peak or Reinforced Reception, are likely to be hot-dropped by other squads, so it's best to approach these locations last to ARC Raiders BluePrints buy avoid unnecessary conflict.
MMOexp ARC Raiders: Consider using alternate exfil routes
- AventurineLe
- 1. Rang
- Tilmeldt: 3. marts 2026 07:47
