Yadea G5 afdrosle via kortslutning
Gamlfar
4. Rang
4. Rang
Tilmeldt: 4. juni 2023 09:23
Scootere: Yadea G5
Ulæst indlæg af Gamlfar »
Faldt over et VGA Vax indlæg hvor man kortslutter en ledning under frontskjoldet, for at få den op i 3. "gear". viewtopic.php?f=30&t=3587&start=20#p25352
Her er et billede af Yadea G5 under frontskjoldet, måske der var ligheder af finde, så man kunne afgrænse og se hvad man skulle gå efter. https://www.elektroroller-forum.de/view ... 88&t=21083 (midt på siden). Måske nogen herinde på forum kan tyde ledningsspaghettien bedre end jeg.
VH
c T
Re: Yadea G5 afdrosle via kortslutning
lexmoto
How to de-restrict the Yadea G5 and Lexmoto E-lex
* Place the bike on the main stand ensuring rear wheel is free,
Ensure the ignition is off,
* Open the throttle fully and hold the front brake on.
* Whilst holding the above turn the ignition on fully.
* Release front brake and quickly press rear brake twice, holding it down on
the second time.
* Release throttle and open/close the throttle twice whilst holding it open
on the second twist.
* Wait 5 seconds and release the rear brake and throttle.
* Open the throttle and check that the speed indicated is more than 30mph.
How to restrict the Yadea G5 and Lexmoto E-lex
* Ensure the ignition is off,
* Open the throttle fully and hold the front brake.
* Whilst still holding the front brake you need to open/close the throttle
twice and hols it open on the second twist.
* Wait 5 seconds then turn off the ignition.
* Open the throttle and check the speed indicated is NO MORE than 30mph.
NOTE: De-restricted the E-Lex will not go above 33mph and the
gear indicator is solid.
If restricted the gear indicator will flash and the bike will not go
above 16mph.
Forsøg på oversættelse:
Lexmoto
Sådan fjernes begrænsningen på Yadea G5 og Lexmoto E-lex
* Placer scooteren på centerstøttebenet, så baghjulet er over jorden,
Sørg for, at tændingen er slukket,
* Drej farthåndtaget helt, og hold forbremsen inde.
* Mens du holder ovenstående, skal du tænde tændingen helt.
* Slip forbremsen, og tryk hurtigt på bagbremsen to gange, og hold den inde den
anden gang.
* Slip farthåndtaget, og drej/slip farthåndtaget to gange, og hold det drejet
den anden gang.
* Vent 5 sekunder, og slip bagbremsen og farthåndtaget.
* Drej farthåndtaget, og tjek, at den angivne hastighed er mere end 30 mph.
Sådan begrænses Yadea G5 og Lexmoto E-lex
* Sørg for, at tændingen er slukket,
* Mens du stadig holder forbremsen, skal du dreje/lukke farthåndtaget
to gange og holde det drejet den anden gang.
* Vent 5 sekunder, og sluk derefter for tændingen.
* Drej farthåndtaget, og tjek, at den angivne hastighed IKKE ER MERE end 30 mph.
BEMÆRK: Fjernes begrænsningen på E-Lex vil den ikke køre hurtigere end 33mph og
gearindikatoren er hele tiden tændt.
Hvis den er begrænset, så blinker gearindikatoren, og scooteren kører ikke
over 16mph.
Gamlfar
4. Rang
4. Rang
Scootere: Yadea G5
Tak for billedet, men jeg har prøvet metoden som desværre ikke virker på min. Måske fordi det er en 30er. I England hvor ovenstående metode vidst kommer fra, findes Yadea G5 kun i 45 og 60 måske også. En anden metode på et tysk forum virkede heller ikke. https://www.elektroroller-forum.de/view ... &start=110
Tænker ikke umiddelbart der er noget med ubrugte ledninger foran til valg af hastighed fordi det lader til at være en trykknap der skifter til næste tilstand.
Men du kan indsamle det du finder om det hvad enten det virker eller ej.
Eventuelt lav en video hvor du prøver det der står så kan vi måske se om du gør noget forkert.
Der står man skal gøre noget hurtigt og noget med antal sekunder så der er sikkert god muligt for at det ikke bliver gjort helt korrekt eller at det der står ikke er helt korrekt.
Eventuelt en video hvor du kan se det bliver gjort så er det måske lettere.
