Vga N1 30 Km/t Ecu Hjælp Euro 4
: 27. oktober 2023 16:55
Er Der nogen der kan hjælpe med opsætning af denne ecu som jeg har læst ud af min VGA N1.
Kode: Vælg alt
[HEADER]
ECS_TYPE=CLC_V504
[PARAMETERS]
N=111
PAR1_DES=ID_MapFile
PAR1_VAL=30002
PAR2_DES=Th_Type
PAR2_VAL=1
PAR3_DES=Th_A_DeltaAccRpm
PAR3_VAL=3000
PAR4_DES=Th_A_DeltaDecRpm
PAR4_VAL=-3000
PAR5_DES=Th_B_DeltaAccTps
PAR5_VAL=200
PAR6_DES=Th_B_Dec_Rpm
PAR6_VAL=1100
PAR7_DES=Th_B_DecTps
PAR7_VAL=5
PAR8_DES=Acc_nRpmDecr
PAR8_VAL=2000
PAR9_DES=Dec_nRpmDecr
PAR9_VAL=1000
PAR10_DES=Air_DeltaAcc
PAR10_VAL=0
PAR11_DES=Air_DeltaDec
PAR11_VAL=0
PAR12_DES=Adv_DeltaAcc
PAR12_VAL=0
PAR13_DES=Adv_DeltaDec
PAR13_VAL=0
PAR14_DES=Adv_DegreeMax
PAR14_VAL=280
PAR15_DES=Adv_LimiterRPM1
PAR15_VAL=9000
PAR16_DES=Adv_LimiterF1
PAR16_VAL=4
PAR17_DES=Adv_LimiterRPM2
PAR17_VAL=9100
PAR18_DES=Adv_LimiterF2
PAR18_VAL=3
PAR19_DES=Adv_LimiterRPM3
PAR19_VAL=9200
PAR20_DES=Adv_LimiterF3
PAR20_VAL=0
PAR21_DES=Adv_LimiterTUNE RPM1
PAR21_VAL=9000
PAR22_DES=Adv_Limiter TUNE F1
PAR22_VAL=4
PAR23_DES=Adv_LimiterTUNE RPM2
PAR23_VAL=9100
PAR24_DES=Adv_Limiter TUNE F2
PAR24_VAL=3
PAR25_DES=Adv_LimiterTUNE RPM3
PAR25_VAL=9200
PAR26_DES=Adv_LimiterTUNE F3
PAR26_VAL=0
PAR27_DES=ClcCheckTime_NoTps
PAR27_VAL=300
PAR28_DES=ClcCheckTime_TpsPresent
PAR28_VAL=30
PAR29_DES=Not_Used
PAR29_VAL=5500
PAR30_DES=Not_Used
PAR30_VAL=6000
PAR31_DES=Not_Used
PAR31_VAL=90
PAR32_DES=Not_Used
PAR32_VAL=2
PAR33_DES=Not_Used
PAR33_VAL=10
PAR34_DES=Not_Used
PAR34_VAL=0
PAR35_DES=Clc_LeanO2
PAR35_VAL=25
PAR36_DES=Clc_RichO2
PAR36_VAL=57
PAR37_DES=Clc_TPSEnLo
PAR37_VAL=105
PAR38_DES=Clc_TPSEnHi
PAR38_VAL=110
PAR39_DES=Clc_deltaTPS
PAR39_VAL=900
PAR40_DES=Clc_StepCycle
PAR40_VAL=2
PAR41_DES=Clc_EnTeng
PAR41_VAL=20
PAR42_DES=Clc_EnRevN
PAR42_VAL=1000
PAR43_DES=Clc_ThresHoldRPM
PAR43_VAL=4000
PAR44_DES=Clc_RPMthCLCOFF
PAR44_VAL=9200
PAR45_DES=Acc_ThRpm_Under_AlgOff
PAR45_VAL=1100
PAR46_DES=Crank_NumRpm
PAR46_VAL=700
PAR47_DES=Warning Engine Temperature Low
PAR47_VAL=150
PAR48_DES=Warning Engine Temperature High
PAR48_VAL=155
PAR49_DES=Emission_Detect_Type
PAR49_VAL=0
PAR50_DES=Engine Temperature Fault
PAR50_VAL=40
PAR51_DES=Air_Frequency
PAR51_VAL=10
PAR52_DES=PickUpOffsetDTC
PAR52_VAL=490
PAR53_DES=Air_En
PAR53_VAL=1
PAR54_DES=Speed_Sensor_Filter
PAR54_VAL=1
PAR55_DES=CLC_En
PAR55_VAL=1
PAR56_DES=CLCCheck_En
PAR56_VAL=1
PAR57_DES=TuneUpCLC_En
PAR57_VAL=1
PAR58_DES=NTC2_En(Teng)
PAR58_VAL=1
PAR59_DES=TPS_En
PAR59_VAL=1
PAR60_DES=Acc_AlgOnTime
PAR60_VAL=0
PAR61_DES=EngStop_En
PAR61_VAL=0
PAR62_DES=AirDoublePWM_En
PAR62_VAL=1
PAR63_DES=AirDPWM_HF
PAR63_VAL=1
PAR64_DES=PickUp Polarity
PAR64_VAL=1
PAR65_DES=TengAdvTuneup
PAR65_VAL=1
PAR66_DES=Acc_ThRpm_Over_AlgOff
PAR66_VAL=8500
PAR67_DES=NTC Fault High Threshold
PAR67_VAL=165
PAR68_DES=NTC Fault Low Threshold
PAR68_VAL=-40
PAR69_DES=Speed_Pulse_Per_Km
PAR69_VAL=30750
PAR70_DES=Speed_Max
PAR70_VAL=44
PAR71_DES=Speed_PID_Proportional
PAR71_VAL=20
PAR72_DES=Speed_PID_Integrative
PAR72_VAL=0
PAR73_DES=Speed_PID_Max_Advance
PAR73_VAL=300
PAR74_DES=Speed_RPM_Treshold
PAR74_VAL=4000
PAR75_DES=Speed_SkipSparks_Limiter
PAR75_VAL=3
PAR76_DES=Adv_DegreeMin
PAR76_VAL=-300
PAR77_DES=Speed_Sensor_EN
PAR77_VAL=0
PAR78_DES=Speed_PID_EN
PAR78_VAL=0
PAR79_DES=Speed_SkipSparks_EN
PAR79_VAL=0
PAR80_DES=ASD_Starter_EN
PAR80_VAL=1
PAR81_DES=TCold_AccDec
PAR81_VAL=20
PAR82_DES=THot_AccDec
PAR82_VAL=120
PAR83_DES=Emission_Temp_1
PAR83_VAL=18
PAR84_DES=Emission_Temp_2
PAR84_VAL=32
PAR85_DES=Emission_Value_1
PAR85_VAL=70
PAR86_DES=Emission_Value_2
PAR86_VAL=85
PAR87_DES=Emission_Time_1
PAR87_VAL=3
PAR88_DES=Emission_Time_2
PAR88_VAL=25
PAR89_DES=Emission_Time_3
PAR89_VAL=50
PAR90_DES=Emission_Time_4
PAR90_VAL=70
PAR91_DES=Emission_Total_Time
PAR91_VAL=950
PAR92_DES=ASD_Full_Power_Emission
PAR92_VAL=1
PAR93_DES=Clc_TPSEnLo_Diag
PAR93_VAL=50
PAR94_DES=ASCII_String_1
PAR94_VAL=51
PAR95_DES=ASCII_String_2
PAR95_VAL=66
PAR96_DES=ASCII_String_3
PAR96_VAL=51
PAR97_DES=ASCII_String_4
PAR97_VAL=32
PAR98_DES=ASCII_String_5
PAR98_VAL=86
PAR99_DES=ASCII_String_6
PAR99_VAL=53
PAR100_DES=ASCII_String_7
PAR100_VAL=48
PAR101_DES=ASCII_String_8
PAR101_VAL=52
PAR102_DES=ASCII_String_9
PAR102_VAL=32
PAR103_DES=ASCII_String_10
PAR103_VAL=51
PAR104_DES=ASCII_String_11
PAR104_VAL=48
PAR105_DES=ASCII_String_12
PAR105_VAL=48
PAR106_DES=ASCII_String_13
PAR106_VAL=48
PAR107_DES=ASCII_String_14
PAR107_VAL=50
PAR108_DES=ASCII_String_15
PAR108_VAL=69
PAR109_DES=ASCII_String_16
PAR109_VAL=52
PAR110_DES=TPS Min Bit 0%
PAR110_VAL=38
PAR111_DES=TPS Max Bit 100%
PAR111_VAL=208
[MAPS]
NUM=19
[MAP1]
N=16
P1A=60
P1B=100
P2A=70
P2B=85
P3A=80
P3B=70
P4A=90
P4B=65
P5A=100
P5B=62
P6A=105
P6B=60
P7A=110
P7B=55
P8A=115
P8B=50
P9A=120
P9B=46
P10A=125
P10B=42
P11A=130
P11B=39
P12A=135
P12B=35
P13A=140
P13B=32
P14A=145
P14B=30
P15A=150
P15B=28
P16A=160
P16B=25
[MAP2]
N=16
P1A=1000
P2A=1600
P3A=1800
P4A=2000
P5A=2500
P6A=3000
P7A=3500
P8A=4000
P9A=5000
P10A=6000
P11A=7000
P12A=7500
P13A=8000
P14A=8200
P15A=8300
P16A=10000
P1B1=130
P1B2=130
P1B3=150
P1B4=150
P1B5=150
P1B6=150
P1B7=150
P1B8=150
P1B9=150
P1B10=150
P1B11=150
P1B12=150
P1B13=150
P1B14=150
P1B15=150
P1B16=150
P2B1=130
P2B2=130
P2B3=150
P2B4=150
P2B5=150
P2B6=150
P2B7=150
P2B8=150
P2B9=150
P2B10=150
P2B11=150
P2B12=150
P2B13=150
P2B14=150
P2B15=150
P2B16=150
P3B1=130
P3B2=130
P3B3=150
P3B4=150
P3B5=150
P3B6=150
P3B7=150
P3B8=150
P3B9=150
P3B10=150
P3B11=150
P3B12=150
P3B13=150
P3B14=150
P3B15=150
P3B16=150
P4B1=130
P4B2=150
P4B3=150
P4B4=150
P4B5=150
P4B6=150
P4B7=150
P4B8=150
P4B9=150
P4B10=150
P4B11=150
P4B12=150
P4B13=150
P4B14=150
P4B15=150
P4B16=150
P5B1=130
P5B2=180
P5B3=180
P5B4=180
P5B5=180
P5B6=180
P5B7=180
P5B8=180
P5B9=180
P5B10=180
P5B11=180
P5B12=180
P5B13=180
P5B14=180
P5B15=180
P5B16=180
P6B1=180
P6B2=220
P6B3=220
P6B4=220
P6B5=220
P6B6=220
P6B7=220
P6B8=220
P6B9=220
P6B10=220
P6B11=220
P6B12=220
P6B13=220
P6B14=220
P6B15=220
P6B16=220
P7B1=250
P7B2=250
P7B3=250
P7B4=250
P7B5=250
P7B6=250
P7B7=250
P7B8=250
P7B9=250
P7B10=250
P7B11=250
P7B12=250
P7B13=250
P7B14=250
P7B15=250
P7B16=250
P8B1=280
P8B2=280
P8B3=280
P8B4=280
P8B5=280
P8B6=280
P8B7=280
P8B8=280
P8B9=280
P8B10=280
P8B11=280
P8B12=280
P8B13=280
P8B14=280
P8B15=280
P8B16=280
P9B1=280
P9B2=280
P9B3=280
P9B4=280
P9B5=280
P9B6=280
P9B7=280
P9B8=280
P9B9=280
P9B10=280
P9B11=280
P9B12=280
P9B13=280
P9B14=280
P9B15=280
P9B16=280
P10B1=280
P10B2=280
P10B3=280
P10B4=280
P10B5=280
P10B6=280
P10B7=280
P10B8=280
P10B9=280
P10B10=280
P10B11=280
P10B12=280
P10B13=280
P10B14=280
P10B15=280
P10B16=280
P11B1=280
P11B2=280
P11B3=280
P11B4=280
P11B5=280
P11B6=280
P11B7=280
P11B8=280
P11B9=280
P11B10=280
P11B11=280
P11B12=280
P11B13=280
P11B14=280
P11B15=280
P11B16=280
P12B1=280
P12B2=280
P12B3=280
P12B4=280
P12B5=280
P12B6=280
P12B7=280
P12B8=280
P12B9=280
P12B10=280
P12B11=280
P12B12=280
P12B13=280
P12B14=280
P12B15=280
P12B16=280
P13B1=240
P13B2=240
P13B3=240
P13B4=240
P13B5=240
P13B6=240
P13B7=240
P13B8=240
P13B9=240
P13B10=240
P13B11=240
P13B12=240
P13B13=240
P13B14=200
P13B15=200
P13B16=200
P14B1=100
P14B2=100
P14B3=100
P14B4=100
P14B5=100
P14B6=100
P14B7=100
P14B8=100
P14B9=100
P14B10=100
P14B11=100
P14B12=100
P14B13=100
P14B14=100
P14B15=100
P14B16=100
P15B1=0
P15B2=0
P15B3=0
P15B4=0
P15B5=0
P15B6=0
P15B7=0
P15B8=0
P15B9=0
P15B10=0
P15B11=0
P15B12=-50
P15B13=-50
P15B14=-50
P15B15=-50
P15B16=-50
P16B1=0
P16B2=0
P16B3=0
P16B4=0
P16B5=0
P16B6=0
P16B7=0
P16B8=0
P16B9=0
P16B10=0
P16B11=0
P16B12=-100
P16B13=-100
P16B14=-100
P16B15=-100
P16B16=-100
P1C=3
P2C=5
P3C=8
P4C=10
P5C=12
P6C=15
P7C=19
P8C=22
P9C=25
P10C=32
P11C=44
P12C=50
P13C=60
P14C=75
P15C=80
P16C=100
[MAP3]
N=16
P1A=1000
P2A=1600
P3A=1800
P4A=2000
P5A=2500
P6A=3000
P7A=3500
P8A=4000
P9A=5000
P10A=6000
P11A=7000
P12A=7500
P13A=8000
P14A=8200
P15A=8300
P16A=10000
P1B1=130
P1B2=130
P1B3=150
P1B4=150
P1B5=150
P1B6=150
P1B7=150
P1B8=150
P1B9=150
P1B10=150
P1B11=150
P1B12=150
P1B13=150
P1B14=150
P1B15=150
P1B16=150
P2B1=130
P2B2=130
P2B3=150
P2B4=150
P2B5=150
P2B6=150
P2B7=150
P2B8=150
P2B9=150
P2B10=150
P2B11=150
P2B12=150
P2B13=150
P2B14=150
P2B15=150
P2B16=150
P3B1=130
P3B2=130
P3B3=150
P3B4=150
P3B5=150
P3B6=150
P3B7=150
P3B8=150
P3B9=150
P3B10=150
P3B11=150
P3B12=150
P3B13=150
P3B14=150
P3B15=150
P3B16=150
P4B1=130
P4B2=150
P4B3=150
P4B4=150
P4B5=150
P4B6=150
P4B7=150
P4B8=150
P4B9=150
P4B10=150
P4B11=150
P4B12=150
P4B13=150
P4B14=150
P4B15=150
P4B16=150
P5B1=130
P5B2=180
P5B3=180
P5B4=180
P5B5=180
P5B6=180
P5B7=180
P5B8=180
P5B9=180
P5B10=180
P5B11=180
P5B12=180
P5B13=180
P5B14=180
P5B15=180
P5B16=180
P6B1=180
P6B2=220
P6B3=220
P6B4=220
P6B5=220
P6B6=220
P6B7=220
P6B8=220
P6B9=220
P6B10=220
P6B11=220
P6B12=220
P6B13=220
P6B14=220
P6B15=220
P6B16=220
P7B1=250
P7B2=250
P7B3=250
P7B4=250
P7B5=250
P7B6=250
P7B7=250
P7B8=250
P7B9=250
P7B10=250
P7B11=250
P7B12=250
P7B13=250
P7B14=250
P7B15=250
P7B16=250
P8B1=280
P8B2=280
P8B3=280
P8B4=280
P8B5=280
P8B6=280
P8B7=280
P8B8=280
P8B9=280
P8B10=280
P8B11=280
P8B12=280
P8B13=280
P8B14=280
P8B15=280
P8B16=280
P9B1=280
P9B2=280
P9B3=280
P9B4=280
P9B5=280
P9B6=280
P9B7=280
P9B8=280
P9B9=280
P9B10=280
P9B11=280
P9B12=280
P9B13=280
P9B14=280
P9B15=280
P9B16=280
P10B1=280
P10B2=280
P10B3=280
P10B4=280
P10B5=280
P10B6=280
P10B7=280
P10B8=280
P10B9=280
P10B10=280
P10B11=280
P10B12=280
P10B13=280
P10B14=280
P10B15=280
P10B16=280
P11B1=280
P11B2=280
P11B3=280
P11B4=280
P11B5=280
P11B6=280
P11B7=280
P11B8=280
P11B9=280
P11B10=280
P11B11=280
P11B12=280
P11B13=280
P11B14=280
P11B15=280
P11B16=280
P12B1=280
P12B2=280
P12B3=280
P12B4=280
P12B5=280
P12B6=280
P12B7=280
P12B8=280
P12B9=280
P12B10=280
P12B11=280
P12B12=280
P12B13=280
P12B14=280
P12B15=280
P12B16=280
P13B1=240
P13B2=240
P13B3=240
P13B4=240
P13B5=240
P13B6=240
P13B7=240
P13B8=240
P13B9=240
P13B10=240
P13B11=240
P13B12=240
P13B13=240
P13B14=200
P13B15=200
P13B16=200
P14B1=100
P14B2=100
P14B3=100
P14B4=100
P14B5=100
P14B6=100
P14B7=100
P14B8=100
P14B9=100
P14B10=100
P14B11=100
P14B12=100
P14B13=100
P14B14=100
P14B15=100
P14B16=100
P15B1=0
P15B2=0
P15B3=0
P15B4=0
P15B5=0
P15B6=0
P15B7=0
P15B8=0
P15B9=0
P15B10=0
P15B11=0
P15B12=-50
P15B13=-50
P15B14=-50
P15B15=-50
P15B16=-50
P16B1=0
P16B2=0
P16B3=0
P16B4=0
P16B5=0
P16B6=0
P16B7=0
P16B8=0
P16B9=0
P16B10=0
P16B11=0
P16B12=-100
P16B13=-100
P16B14=-100
P16B15=-100
P16B16=-100
P1C=3
P2C=5
P3C=8
P4C=10
P5C=12
P6C=15
P7C=19
P8C=22
P9C=25
P10C=32
P11C=44
P12C=50
P13C=60
P14C=75
P15C=80
P16C=100
[MAP4]
N=6
P1A=3000
P2A=3500
P3A=5000
P4A=7400
P5A=8400
P6A=9000
P1B1=10
P1B2=10
P1B3=10
P1B4=10
P1B5=10
P1B6=10
P1B7=10
P1B8=10
P1B9=10
P1B10=10
P2B1=10
P2B2=10
P2B3=10
P2B4=10
P2B5=10
P2B6=10
P2B7=10
P2B8=10
P2B9=10
P2B10=10
P3B1=10
P3B2=10
P3B3=10
P3B4=10
P3B5=10
P3B6=10
P3B7=10
P3B8=10
P3B9=10
P3B10=10
P4B1=10
P4B2=10
P4B3=10
P4B4=10
P4B5=10
P4B6=10
P4B7=10
P4B8=10
P4B9=10
P4B10=10
P5B1=10
P5B2=10
P5B3=10
P5B4=10
P5B5=10
P5B6=10
P5B7=10
P5B8=10
P5B9=10
P5B10=10
P6B1=10
P6B2=10
P6B3=10
P6B4=10
P6B5=10
P6B6=10
P6B7=10
P6B8=10
P6B9=10
P6B10=10
P1C=0
P2C=3
P3C=5
P4C=10
P5C=20
P6C=30
P7C=40
P8C=60
P9C=80
P10C=100
[MAP5]
N=6
P1A=3000
P2A=3500
P3A=5000
P4A=7400
P5A=8400
P6A=9000
P1B1=0
P1B2=0
P1B3=0
P1B4=0
P1B5=0
P1B6=0
P1B7=0
P1B8=0
P1B9=0
P1B10=0
P2B1=0
P2B2=1
P2B3=1
P2B4=1
P2B5=1
P2B6=1
P2B7=1
P2B8=0
P2B9=1
P2B10=1
P3B1=0
P3B2=1
P3B3=1
P3B4=1
P3B5=1
P3B6=1
P3B7=1
P3B8=0
P3B9=1
P3B10=1
P4B1=0
P4B2=1
P4B3=1
P4B4=1
P4B5=1
P4B6=1
P4B7=1
P4B8=0
P4B9=1
P4B10=1
P5B1=0
P5B2=1
P5B3=1
P5B4=1
P5B5=1
P5B6=1
P5B7=1
P5B8=0
P5B9=1
P5B10=1
P6B1=0
P6B2=0
P6B3=0
P6B4=0
P6B5=0
P6B6=0
P6B7=0
P6B8=0
P6B9=0
P6B10=0
P1C=0
P2C=3
P3C=5
P4C=10
P5C=20
P6C=30
P7C=40
P8C=60
P9C=80
P10C=100
[MAP6]
N=6
P1A=3000
P2A=3500
P3A=5000
P4A=7400
P5A=8400
P6A=9000
P1B1=1
P1B2=1
P1B3=1
P1B4=1
P1B5=1
P1B6=1
P1B7=1
P1B8=1
P1B9=1
P1B10=1
P2B1=1
P2B2=1
P2B3=1
P2B4=1
P2B5=1
P2B6=1
P2B7=1
P2B8=1
P2B9=1
P2B10=1
P3B1=1
P3B2=1
P3B3=1
P3B4=1
P3B5=1
P3B6=1
P3B7=1
P3B8=1
P3B9=1
P3B10=1
P4B1=1
P4B2=1
P4B3=1
P4B4=1
P4B5=1
P4B6=1
P4B7=1
P4B8=1
P4B9=1
P4B10=1
P5B1=1
P5B2=1
P5B3=1
P5B4=1
P5B5=1
P5B6=1
P5B7=1
P5B8=1
P5B9=1
P5B10=1
P6B1=1
P6B2=1
P6B3=1
P6B4=1
P6B5=1
P6B6=1
P6B7=1
P6B8=1
P6B9=1
P6B10=1
P1C=0
P2C=3
P3C=5
P4C=10
P5C=20
P6C=30
P7C=40
P8C=60
P9C=80
P10C=100
[MAP7]
N=6
P1A=3000
P2A=3500
P3A=5000
P4A=7400
P5A=8400
P6A=9000
P1B1=0
P1B2=0
P1B3=0
P1B4=0
P1B5=0
P1B6=0
P1B7=0
P1B8=0
P1B9=0
P1B10=0
P2B1=0
P2B2=0
P2B3=0
P2B4=0
P2B5=0
P2B6=0
P2B7=0
P2B8=0
P2B9=0
P2B10=0
P3B1=0
P3B2=0
P3B3=0
P3B4=0
P3B5=0
P3B6=0
P3B7=0
P3B8=0
P3B9=0
P3B10=0
P4B1=0
P4B2=0
P4B3=0
P4B4=0
P4B5=0
P4B6=0
P4B7=0
P4B8=0
P4B9=0
P4B10=0
P5B1=0
P5B2=0
P5B3=0
P5B4=0
P5B5=0
P5B6=0
P5B7=0
P5B8=0
P5B9=0
P5B10=0
P6B1=0
P6B2=0
P6B3=0
P6B4=0
P6B5=0
P6B6=0
P6B7=0
P6B8=0
P6B9=0
P6B10=0
P1C=0
P2C=3
P3C=5
P4C=10
P5C=20
P6C=30
P7C=40
P8C=60
P9C=80
P10C=100
[MAP8]
N=16
P1A=1200
P2A=1500
P3A=2000
P4A=3500
P5A=4000
P6A=4500
P7A=5000
P8A=5500
P9A=6000
P10A=6500
P11A=7000
P12A=7500
P13A=8000
P14A=8500
P15A=9000
P16A=11000
P1B1=1
P1B2=1
P1B3=1
P1B4=1
P1B5=1
P1B6=1
P1B7=1
P1B8=1
P1B9=1
P1B10=1
P1B11=1
P1B12=1
P1B13=1
P1B14=1
P1B15=1
P1B16=1
P2B1=1
P2B2=1
P2B3=1
P2B4=1
P2B5=1
P2B6=1
P2B7=1
P2B8=1
P2B9=1
P2B10=1
P2B11=1
P2B12=1
P2B13=1
P2B14=1
P2B15=1
P2B16=1
P3B1=1
P3B2=1
P3B3=1
P3B4=1
P3B5=1
P3B6=1
P3B7=1
P3B8=1
P3B9=1
P3B10=1
P3B11=1
P3B12=1
P3B13=1
P3B14=1
P3B15=1
P3B16=1
P4B1=1
P4B2=1
P4B3=1
P4B4=1
P4B5=1
P4B6=1
P4B7=1
P4B8=1
P4B9=1
P4B10=1
P4B11=1
P4B12=1
P4B13=1
P4B14=1
P4B15=1
P4B16=1
P5B1=1
P5B2=1
P5B3=1
P5B4=1
P5B5=1
P5B6=1
P5B7=1
P5B8=1
P5B9=1
P5B10=1
P5B11=1
P5B12=1
P5B13=1
P5B14=1
P5B15=1
P5B16=1
P6B1=1
P6B2=1
P6B3=1
P6B4=1
P6B5=1
P6B6=1
P6B7=1
P6B8=1
P6B9=1
P6B10=1
P6B11=1
P6B12=1
P6B13=1
P6B14=1
P6B15=1
P6B16=1
P7B1=60
P7B2=50
P7B3=50
P7B4=50
P7B5=30
P7B6=30
P7B7=30
P7B8=1
P7B9=1
P7B10=1
P7B11=1
P7B12=1
P7B13=1
P7B14=1
P7B15=1
P7B16=1
P8B1=100
P8B2=50
P8B3=70
P8B4=70
P8B5=60
P8B6=50
P8B7=50
P8B8=1
P8B9=1
P8B10=1
P8B11=1
P8B12=1
P8B13=1
P8B14=1
P8B15=1
P8B16=1
P9B1=100
P9B2=50
P9B3=60
P9B4=60
P9B5=60
P9B6=50
P9B7=50
P9B8=1
P9B9=1
P9B10=1
P9B11=1
P9B12=1
P9B13=1
P9B14=1
P9B15=1
P9B16=1
P10B1=100
P10B2=50
P10B3=50
P10B4=50
P10B5=50
P10B6=50
P10B7=50
P10B8=1
P10B9=1
P10B10=1
P10B11=1
P10B12=1
P10B13=1
P10B14=1
P10B15=10
P10B16=10
P11B1=100
P11B2=50
P11B3=40
P11B4=40
P11B5=40
P11B6=50
P11B7=50
P11B8=1
P11B9=1
P11B10=1
P11B11=1
P11B12=1
P11B13=1
P11B14=1
P11B15=30
P11B16=30
P12B1=100
P12B2=1
P12B3=1
P12B4=1
P12B5=1
P12B6=1
P12B7=1
P12B8=1
P12B9=1
P12B10=1
P12B11=1
P12B12=1
P12B13=1
P12B14=1
P12B15=30
P12B16=30
P13B1=100
P13B2=1
P13B3=1
P13B4=1
P13B5=1
P13B6=1
P13B7=1
P13B8=1
P13B9=1
P13B10=1
P13B11=1
P13B12=1
P13B13=1
P13B14=30
P13B15=50
P13B16=50
P14B1=1
P14B2=1
P14B3=1
P14B4=1
P14B5=1
P14B6=1
P14B7=1
P14B8=1
P14B9=1
P14B10=1
P14B11=1
P14B12=1
P14B13=1
P14B14=50
P14B15=50
P14B16=50
P15B1=1
P15B2=1
P15B3=1
P15B4=1
P15B5=1
P15B6=1
P15B7=1
P15B8=1
P15B9=1
P15B10=1
P15B11=1
P15B12=1
P15B13=1
P15B14=50
P15B15=50
P15B16=50
P16B1=1
P16B2=1
P16B3=1
P16B4=1
P16B5=1
P16B6=1
P16B7=1
P16B8=1
P16B9=1
P16B10=1
P16B11=1
P16B12=1
P16B13=1
P16B14=1
P16B15=1
P16B16=1
P1C=1
P2C=3
P3C=5
P4C=10
P5C=15
P6C=20
P7C=25
P8C=30
P9C=35
P10C=40
P11C=50
P12C=60
P13C=70
P14C=80
P15C=90
P16C=100
[MAP9]
N=16
P1A=1200
P2A=1500
P3A=2000
P4A=3500
P5A=4000
P6A=4500
P7A=5000
P8A=5500
P9A=6000
P10A=6500
P11A=7000
P12A=7500
P13A=8000
P14A=8500
P15A=9000
P16A=11000
P1B1=1
P1B2=1
P1B3=1
P1B4=1
P1B5=1
P1B6=1
P1B7=1
P1B8=1
P1B9=1
P1B10=1
P1B11=1
P1B12=1
P1B13=1
P1B14=1
P1B15=1
P1B16=1
P2B1=1
P2B2=1
P2B3=1
P2B4=1
P2B5=1
P2B6=1
P2B7=1
P2B8=1
P2B9=1
P2B10=1
P2B11=1
P2B12=1
P2B13=1
P2B14=1
P2B15=1
P2B16=1
P3B1=1
P3B2=1
P3B3=1
P3B4=1
P3B5=1
P3B6=1
P3B7=1
P3B8=1
P3B9=1
P3B10=1
P3B11=1
P3B12=1
P3B13=1
P3B14=1
P3B15=1
P3B16=1
P4B1=1
P4B2=1
P4B3=1
P4B4=1
P4B5=1
P4B6=1
P4B7=1
P4B8=1
P4B9=1
P4B10=1
P4B11=1
P4B12=1
P4B13=1
P4B14=1
P4B15=1
P4B16=1
P5B1=1
P5B2=1
P5B3=1
P5B4=1
P5B5=1
P5B6=1
P5B7=1
P5B8=1
P5B9=1
P5B10=1
P5B11=1
P5B12=1
P5B13=1
P5B14=1
P5B15=1
P5B16=1
P6B1=1
P6B2=1
P6B3=1
P6B4=1
P6B5=1
P6B6=1
P6B7=1
P6B8=1
P6B9=1
P6B10=1
P6B11=1
P6B12=1
P6B13=1
P6B14=1
P6B15=1
P6B16=1
P7B1=60
P7B2=50
P7B3=50
P7B4=50
P7B5=30
P7B6=30
P7B7=30
P7B8=1
P7B9=1
P7B10=1
P7B11=1
P7B12=1
P7B13=1
P7B14=1
P7B15=1
P7B16=1
P8B1=100
P8B2=50
P8B3=70
P8B4=70
P8B5=60
P8B6=50
P8B7=50
P8B8=1
P8B9=1
P8B10=1
P8B11=1
P8B12=1
P8B13=1
P8B14=1
P8B15=1
P8B16=1
P9B1=100
P9B2=50
P9B3=60
P9B4=60
P9B5=60
P9B6=50
P9B7=50
P9B8=1
P9B9=1
P9B10=1
P9B11=1
P9B12=1
P9B13=1
P9B14=1
P9B15=1
P9B16=1
P10B1=100
P10B2=50
P10B3=50
P10B4=50
P10B5=50
P10B6=50
P10B7=50
P10B8=1
P10B9=1
P10B10=1
P10B11=1
P10B12=1
P10B13=1
P10B14=1
P10B15=10
P10B16=10
P11B1=100
P11B2=50
P11B3=40
P11B4=40
P11B5=40
P11B6=50
P11B7=50
P11B8=1
P11B9=1
P11B10=1
P11B11=1
P11B12=1
P11B13=1
P11B14=1
P11B15=30
P11B16=30
P12B1=100
P12B2=1
P12B3=1
P12B4=1
P12B5=1
P12B6=1
P12B7=1
P12B8=1
P12B9=1
P12B10=1
P12B11=1
P12B12=1
P12B13=1
P12B14=1
P12B15=30
P12B16=30
P13B1=100
P13B2=1
P13B3=1
P13B4=1
P13B5=1
P13B6=1
P13B7=1
P13B8=1
P13B9=1
P13B10=1
P13B11=1
P13B12=1
P13B13=1
P13B14=30
P13B15=50
P13B16=50
P14B1=1
P14B2=1
P14B3=1
P14B4=1
P14B5=1
P14B6=1
P14B7=1
P14B8=1
P14B9=1
P14B10=1
P14B11=1
P14B12=1
P14B13=1
P14B14=50
P14B15=50
P14B16=50
P15B1=1
P15B2=1
P15B3=1
P15B4=1
P15B5=1
P15B6=1
P15B7=1
P15B8=1
P15B9=1
P15B10=1
P15B11=1
P15B12=1
P15B13=1
P15B14=50
P15B15=50
P15B16=50
P16B1=1
P16B2=1
P16B3=1
P16B4=1
P16B5=1
P16B6=1
P16B7=1
P16B8=1
P16B9=1
P16B10=1
P16B11=1
P16B12=1
P16B13=1
P16B14=1
P16B15=1
P16B16=1
P1C=1
P2C=3
P3C=5
P4C=10
P5C=15
P6C=20
P7C=25
P8C=30
P9C=35
P10C=40
P11C=50
P12C=60
P13C=70
P14C=80
P15C=90
P16C=100
[MAP10]
N=6
P1A=1600
P2A=1800
P3A=2000
P4A=2500
P5A=5000
P6A=6000
P1B1=0
P1B2=0
P1B3=0
P1B4=0
P1B5=0
P1B6=0
P1B7=0
P1B8=0
P2B1=0
P2B2=0
P2B3=0
P2B4=0
P2B5=0
P2B6=0
P2B7=0
P2B8=0
P3B1=0
P3B2=0
P3B3=0
P3B4=0
P3B5=0
P3B6=0
P3B7=0
P3B8=0
P4B1=0
P4B2=0
P4B3=0
P4B4=0
P4B5=0
P4B6=0
P4B7=0
P4B8=0
P5B1=0
P5B2=0
P5B3=0
P5B4=0
P5B5=0
P5B6=0
P5B7=0
P5B8=0
P6B1=0
P6B2=0
P6B3=0
P6B4=0
P6B5=0
P6B6=0
P6B7=0
P6B8=0
P1C=-20
P2C=18
P3C=20
P4C=30
P5C=50
P6C=70
P7C=100
P8C=120
[MAP11]
N=6
P1A=1600
P2A=1800
P3A=2000
P4A=2500
P5A=5000
P6A=6000
P1B1=0
P1B2=0
P1B3=0
P1B4=0
P1B5=0
P1B6=0
P1B7=0
P1B8=0
P2B1=0
P2B2=0
P2B3=0
P2B4=0
P2B5=0
P2B6=0
P2B7=0
P2B8=0
P3B1=0
P3B2=0
P3B3=0
P3B4=0
P3B5=0
P3B6=0
P3B7=0
P3B8=0
P4B1=0
P4B2=0
P4B3=0
P4B4=0
P4B5=0
P4B6=0
P4B7=0
P4B8=0
P5B1=0
P5B2=0
P5B3=0
P5B4=0
P5B5=0
P5B6=0
P5B7=0
P5B8=0
P6B1=0
P6B2=0
P6B3=0
P6B4=0
P6B5=0
P6B6=0
P6B7=0
P6B8=0
P1C=-20
P2C=18
P3C=20
P4C=30
P5C=50
P6C=70
P7C=100
P8C=120
[MAP12]
N=16
P1A=199
P1B=-30
P2A=167
P2B=-20
P3A=139
P3B=-10
P4A=112
P4B=0
P5A=95
P5B=10
P6A=81
P6B=20
P7A=73
P7B=30
P8A=68
P8B=40
P9A=64
P9B=50
P10A=58
P10B=60
P11A=56
P11B=70
P12A=53
P12B=80
P13A=50
P13B=90
P14A=49
P14B=100
P15A=46
P15B=120
P16A=45
P16B=121
[MAP13]
N=6
P1A=1600
P2A=1800
P3A=2000
P4A=2500
P5A=5000
P6A=6000
P1B1=80
P1B2=80
P1B3=50
P1B4=50
P1B5=40
P1B6=0
P1B7=0
P1B8=0
P2B1=80
P2B2=80
P2B3=50
P2B4=50
P2B5=20
P2B6=0
P2B7=0
P2B8=0
P3B1=80
P3B2=80
P3B3=50
P3B4=0
P3B5=0
P3B6=-40
P3B7=-50
P3B8=-50
P4B1=80
P4B2=80
P4B3=50
P4B4=0
P4B5=0
P4B6=0
P4B7=0
P4B8=0
P5B1=30
P5B2=30
P5B3=30
P5B4=0
P5B5=0
P5B6=0
P5B7=0
P5B8=0
P6B1=0
P6B2=0
P6B3=0
P6B4=0
P6B5=0
P6B6=0
P6B7=0
P6B8=0
P1C=-20
P2C=18
P3C=20
P4C=30
P5C=50
P6C=70
P7C=100
P8C=120
[MAP14]
N=6
P1A=1600
P2A=1800
P3A=2000
P4A=2500
P5A=5000
P6A=6000
P1B1=-100
P1B2=-100
P1B3=-100
P1B4=-100
P1B5=-100
P1B6=-100
P1B7=0
P1B8=0
P2B1=-100
P2B2=-100
P2B3=-100
P2B4=-100
P2B5=-50
P2B6=0
P2B7=0
P2B8=0
P3B1=-100
P3B2=-100
P3B3=-100
P3B4=-50
P3B5=0
P3B6=0
P3B7=0
P3B8=0
P4B1=-100
P4B2=-100
P4B3=0
P4B4=0
P4B5=0
P4B6=0
P4B7=0
P4B8=0
P5B1=-100
P5B2=-100
P5B3=0
P5B4=0
P5B5=0
P5B6=0
P5B7=0
P5B8=0
P6B1=-100
P6B2=-100
P6B3=0
P6B4=0
P6B5=0
P6B6=0
P6B7=0
P6B8=0
P1C=-20
P2C=18
P3C=20
P4C=30
P5C=50
P6C=70
P7C=100
P8C=120
[MAP15]
N=16
P1A=251
P1B=-40
P2A=243
P2B=-20
P3A=223
P3B=0
P4A=206
P4B=10
P5A=185
P5B=20
P6A=161
P6B=30
P7A=136
P7B=40
P8A=111
P8B=50
P9A=88
P9B=60
P10A=69
P10B=70
P11A=54
P11B=80
P12A=42
P12B=90
P13A=32
P13B=100
P14A=25
P14B=120
P15A=12
P15B=140
P16A=6
P16B=170
[MAP16]
N=8
P1A=-10
P1B=0
P2A=15
P2B=0
P3A=18
P3B=50
P4A=20
P4B=100
P5A=80
P5B=100
P6A=90
P6B=50
P7A=110
P7B=50
P8A=130
P8B=50
[MAP17]
N=8
P1A=-10
P1B=0
P2A=15
P2B=0
P3A=18
P3B=0
P4A=20
P4B=0
P5A=80
P5B=0
P6A=90
P6B=0
P7A=110
P7B=0
P8A=130
P8B=0
[MAP18]
N=6
P1A=3000
P1B=0
P2A=3500
P2B=0
P3A=4500
P3B=0
P4A=6300
P4B=0
P5A=7000
P5B=0
P6A=8000
P6B=0
[MAP19]
N=6
P1A=3000
P1B=0
P2A=3500
P2B=0
P3A=4500
P3B=0
P4A=6300
P4B=0
P5A=7000
P5B=0
P6A=8000
P6B=0
